Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #16 (permalink)
Old 12-21-2005, 01:05 PM
Deano83 Deano83 is offline
Garage is empty, add now
Deano83 is starting off with a positive reputation.
you could over-spool your turbo, so you need to set the wastegate to a certain boost. you do this by adjusting the copper coloered rod on the back of the turbo.
  #17 (permalink)
Old 12-21-2005, 03:40 PM
BadAss01F250 BadAss01F250 is offline
BadAss01F250 is starting off with a positive reputation.
how do you go about adjusting the rod on the wastegate for more boost?
  #18 (permalink)
Old 12-21-2005, 04:50 PM
wlihntr's Avatar
wlihntr wlihntr is offline
wlihntr has a good reputation on FTE.wlihntr has a good reputation on FTE.
Quote:
i posted instructions on how do it a while ago, but here they are again
ok i just finished the "shorten your rod mod" WARNING: this is not that easy and has the potential to lose all kinds of tools and srews so be careful. remove the two clamps on the cold side charge tube on top of the engine(gives you ,more room to work)next you will need to remove the clip holding the rod to the waste gate, you will need a mechanics mirror to see what you are doing. i used a corkscrew from a swissarmy kinfe to get the clip off. the clip will go flying and like was said before 99% of the time you will not find it(i on the other hand am in that 1%...I FOUND THE CLIP!!)now move to the other side of the engine bay and remove the actuator(the gold canister)it is held on by 2 10mm bolts they are on the inside of the bracket and are a little difficult to get to, also be careful when you take the bolts off, if you drop them you are probable not going to find them.take the whole assembley out and screw in the rod on the threaded part. it will not screw in all the way to the end of the threads there will be about 1/4-1/2 inch left. now put the assembley back and hook the rod back to the waste gate. it will be difficult to ovecome the spring pressure to get the rod back in place.i used a pair of plumers pliers and came from the drivers side i gripped the rod in my right hand with the pliers and used a long screwdriver to hold the wastegate in place. this is the reason you dont put the bolts in yet, if you can not get the rod hooked back up you will have to take it out and make it a little longer. i was able to screw the rod in as far as it would go and reattach it(it was not easy)...good luck
__________________
2001 Powerstroke, CC,SB,Lariat,Auto,4X4
Mods. in Gallery
2007 Lincoln MKZ awd
http://www.ford-trucks.com/user_gall...oid=65664&.jpg
its good to have an open mind...but not so open that your brains fall out
  #19 (permalink)
Old 03-23-2008, 08:35 AM
c00nhunterjoe's Avatar
c00nhunterjoe c00nhunterjoe is offline
c00nhunterjoe has a very good reputation on FTE.c00nhunterjoe has a very good reputation on FTE.c00nhunterjoe has a very good reputation on FTE.
how much of a difference is this? does it do the same thing as the banks big head wasgate actuator?
__________________
The name's Joe. I blow sheet up for a living, then get paid to fix it, and blow it up again.
http://www.youtube.com/user/c00nhunterjoe
http://community.webshots.com/user/c00nhunterjoe
  #20 (permalink)
Old 03-23-2008, 09:10 AM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
1999 Ford F-550
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
http://www.facebook.com/http://facebook.com/Kwikkordead#!/Kwikkordead
If you have access to compressed air, the easiest way to get that rod back on the WG lever is to pressurize the canister (gently!) and the rod extends out and you can simply drop it onto the WG lever. The air pressure overcomes the spring pressure effortlessly.
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, Titan 520's, CCV, EGR, CAT.
2000 VW Passat 1.8t Tiptronic. ZZOOOOOMMMM!!!
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
You cannot explain or explain away the power of God.
  #21 (permalink)
Old 03-23-2008, 09:54 AM
MTDewX's Avatar
MTDewX MTDewX is offline
MTDewX is starting off with a positive reputation.
I just got a new toy from Dieselsite, and it seem to work pretty well, as waste-gates go. I think its better than just un-plugging the red line. this will still release when it gets to your pre-setted psi.
http://www.dieselsite.com/index.asp?...S&Category=569
  #22 (permalink)
Old 04-13-2008, 05:24 PM
distortedcloud's Avatar
distortedcloud distortedcloud is offline
distortedcloud is starting off with a positive reputation.
I'm just about to put everything back together, and I am wondering if this will cause problems with the turbo? Just curious......
also is there any easier way to get the rod back on? the old man has the compressor(waiting for him to come back).
nevermind, I found the air compressor tucked away in the garbage. Thanks Kwik for the idea of using it.
Tags
2001, 64, 73, 73l, actuator, adjusting, boost, diesel, ford, gate, levers, powerstroke, turbo, waste, wastegate, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
