Go Back   Ford Truck Enthusiasts Forums > Misc. > Appearance & Dress-Up
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Appearance & Dress-Up SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 12-20-2005, 04:46 PM
yechave yechave is offline
yechave is starting off with a positive reputation.
how to remove veneer instrument panels?
I have a 97 econoline with Chariot conversion vans wood veneer panels over the gauges and radio. This was removed once by a Ford dealer for heater control repairs, and never reinstalled properly. How do you remove the wood veneer, and what is used to get the adhesive off the plastic factory panel, if it can be done. Thanks!
  #2 (permalink)
Old 02-24-2006, 12:08 PM
For anyone interested, this is how I accomplished the job. I first tried using a hair dryer, with the bezels still on the dash. In the end, I found it much easier to remove the two bezzels as one piece...remove the two screws above the speedometer, remove the headlamp ring, and switch pull, then pop the two bezels off. Nothing else needs to be removed to do this. Then, using the hair dryer, heat up the veneer, I highly suggest using gloves to do this. You will be left with a very well adhered backing in most places. Again, use the heat gun and a firm plastic pot scrapper, used in a slicing motion. That will remove 95% of all the glue. Then, wipe off the adhesive film left, using alcohol, and then remove that film with Goo remover. End product looks damn good!
"Old too soon, smart too late!"
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
