Sticky throttle in 97 Explorer 5.0
hey all,
i have a small problem in my 97 explorer 5.0. when i hit the pedal its almost like its stuck at first, and then goes and revs and takes off like almost spinning the tires. my mpg is horrible, about 13.2 mpg. i traced the problem back to the throttle body. I took the black plastic housing and the air intake tubing off and exposed the round plate that moves up and down. with the truck off i was pushing it with my hand and had the same sticky problem. i put some oil on the outside of it where the cable meets the throttle body with that piece that turns the round plate. i also put some oil on the inside of the throttle body on the 2 sides where it pivots to move. (i put very little almost barely noticeable because only air should go thru there). and then i test drove it. it seems to have gone away about 95%. is there something else i should have done or do i need a new throttle body? because i'm sure once the oil dries up i'll need to do it again. i used regular household oil in the plastic container that you could get at walmart.....
thanks.
thanks.
yea i was thinking of adjusting the stop screw (turning it up a little) but wouldnt that cause me to idle higher and use more gas?? the tb has a sticker on it that says "do not clean tb, it has a special coating" or something to that effect.... so i am a little hesitant to spray it with carb cleaner. should i just ignore that? there is this white residue all over the inside of it.....and its sticky...
I have the same problem on my 5.0 97EB. It shows up after I'd driven it around for at least half an hour, usually at highway speeds. It's also occurs very frequently in hot weather. And if I let it sit for about 5 minutes, it goes away - for a while.
But so far this winter, I haven't had any problems - none. It really looks like the hot weather contributes somehow.
I'm pretty sure it's not the coating on the TB that's causing the sticking - it's been gone on mine since I bought it (used). I've sprayed the TB with carb cleaner and used some WD40 on the outside linkage. That seemed to help - but it wasn't a cure. The problem came back in in a couple of weeks - until winter arrived.
Just a thought: could it be possible that there is something in the cruise controller causing the problem?
Still looking for a cure rather than a temporary fix.
Just clean up the sticky crude. I used TB cleaner on a rag. I found that cheap gas (non branded) caused the build up. Mine happens after using the cruise control for a period of time. I also found that switching between branded and non branded, every other fill up, solved the problem. I still have the orginal TB after 142K miles.
i sprayed it with the tb cleaner and the problem is about 80% gone. i dont have wd40 but i will get a can tomorrow. also sprayed down the whole air intake tubing and the MAF. i took the maf off the air box and sprayed it down, both sides and also sprayed the little sensor. truck didnt start right away. about 4th try it started and stalled. then i started it one more time then gave it throttle and its worked fine since then. the pedal is barely sticky but still there....it'll get wd40'd tomorrow and we'll see. i have a used tb coming from another 97 with 40k miles on it, only paid $24 total.
I had this problem with my 1997 4.0 SOHC. When I took it to the dealer, they replaced the throttle body under warranty. Then, about a month later, Ford announced a recall for the very same reason. I guess they had had enough warranty repairs for the Feds to order a recall. I do not know if there was a similar recall for your 5.0. Anyway your taking care of it.
Tenn01PSD350
50
10-21-2019 12:58 PM
2150 carb. how do you take this part off?? I need to swap this part but dont know it it comes off?..
F350dog
11-03-2015 06:51 PM
SideWinder4.9l
27
09-26-2011 11:21 PM
shagnwagn
12-06-2004 11:56 AM
