Trouble replacing fuel filter!
I bought a little tool that slips in the ends so you can pull the barbed ends out and the rear side comes right apart but I can't for the life of me get the front to release. Anyone else have that problem? I'm about to cut the nipple off and use a piece of hose and clamps to hold the one side.
The tool I bought looks like a pair of double ended pliers that fits around two different sizes of tubing, is there a better tool?
U have the right tool, but they can be a bear to get off. I struggled with my first one and ended up coated in tar from the fuel melting the undercoating. There should be a clip holding in the other side that goes through the line. Look at the new filter and you will see what i'm talking about. Just pull it out. The new filter should come with the new clips.
as a last resort, grab the plastic slide on piece with a pair of pliers, stick a big screwdriver betweent eh filter can and the pliers and pry the plastic tube off the end. the sheetmetal retainer will bend and give up eventually. you can then slide the new filter in the plastic end and put on the plastic retainer clip. what you will be missing is the sheetmetal safety clip. i have had to do that before.---- but the tool should work.
Don't cut the fuel line and use hose and clamps to put it back together. The fuel is under about 90psi pressure and you don't want it blowing apart.
Push the fuel line in towards the filter while you push the tool into the line.
If that doesn't work you can cut the end of the filter "fitting" so you can work on the line easier. Once you get fuel line down after cutting off the end of the filter you'll be able to see the "fingers" of the retainer clip and you may be able to see why they wont release.
