Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
  #1 (permalink)
Old 12-19-2005, 07:59 PM
stevef100s stevef100s is offline
Garage is empty, add now
stevef100s is new and has a neutral reputation at this point.
Fog Lights OFF.....High Beams On
Has anybody come up with a solution? I just found this out over the weekend. For some reason, Ford designed things screwy. I for one, would like my fog lights to stay on while the high beam headlights are on. My friends Toyota is the exact same way.
  #2 (permalink)
Old 12-19-2005, 08:29 PM
Blurry94's Avatar
Blurry94 Blurry94 is offline
1994 Ford Lightning
Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.
I installed a jumper wire on the switch of my 94 (in 96) and it works fine and no troubles.
__________________
Matt C.
Intercooled Vortech, Victor Jr. heads, roller cam, 62lb injectors, 2800 stall converter, Eaton Locker, Pickrel Headers and Exhaust, FMS Mass Air using SCT tuning software. Road trip and dragstrip ready!
  #3 (permalink)
Old 12-19-2005, 08:39 PM
Bdox's Avatar
Bdox Bdox is offline
Iconoclast
2008 Ford F-150
Bdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputation
They are like that because of legislation that fog light should only operate with low beams.
It's easy to change. Splice in a new hot wire to the fogs that is independant of the light switch.
__________________
Bruce
corporations are not persons
corporations are not persons. corporations are not persons.corporations are not persons. corporations are not persons. corporations are not persons.
  #4 (permalink)
Old 12-19-2005, 09:29 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
no need for a new wire. do a search for this. you need to ground out a prong in the relay. also the law has nothing to do with Fog lights by themselves . it simply states it is illegal to exceed a certain amount of watts. this is a serious offense here in cal will run you 500.00 and a fix it ticket.
  #5 (permalink)
Old 12-19-2005, 10:18 PM
I DID do a search first. Wouldn't you? I looked up fog lights under the Lightning section. I read for two days (not quite), but found nothing of what I needed. Any better help, then "do a search"?
  #6 (permalink)
Old 12-19-2005, 11:37 PM
there is a write up at f150 online.
  #7 (permalink)
Old 12-20-2005, 01:00 AM
Bdox's Avatar
Iconoclast
2008 Ford F-150
Quote:
Look up the law before you dismiss what someone else says. Who knows? They just might be in possession of a fact or two that you are unaware of.
__________________
Bruce
  #8 (permalink)
Old 12-22-2005, 12:50 AM
Smaug's Avatar
Smaug Smaug is offline
Smaug is starting off with a positive reputation.
no need to mess w/ the wires, you can drill out part of the switch.
EDIT:just spent 30 minutes looking for a link and can't find it. I'll look again later and post it. It's either in the 97-03 F150 or Expy forum.
__________________
97 F150 Flareside-3/5 drop, 99-up frt end w/ 00 Harley valance, 18 in ARE rims, black APC headlights, '04 corners and 'L' tails
05 Expedition-my better half's
66 Mustang C-code C4 Coupe-thanks to my better half!
65 Mustang C-code 3 spd Coupe- project for my son
  #9 (permalink)
Old 12-22-2005, 09:49 AM
Smaug's Avatar
found it and you do have to put a jumper in
http://www.ford-trucks.com/forums/sh...d.php?t=234912
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
