Engine Oil Cooler lines for a 98 f150 4.6l. - Ford Truck Enthusiasts Forums
Old 12-19-2005, 11:50 AM
jasonhoodenpyle jasonhoodenpyle is offline
jasonhoodenpyle is starting off with a positive reputation.
Mine are leaking at the factory crimp, so I am guessing I have to replace the whole thing. Anyone dealt with this problem? I don't really want to spend the $200 for the part at Ford, so if anyone has any suggestions let me know.
TIA,
Jason.
Old 12-20-2005, 01:26 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
A local Parker store may be able to make a new set cheaper.
Old 12-20-2005, 05:20 PM
great white great white is offline
great white is starting off with a positive reputation.
I am confronted with the same issue. All 4 of my crimps are "sweating" oil. I have the 4.6L Romeo and not sure what adapter will work (mounting to block). I know for sure I am not paying $190 for the replacement from the dealer. I have looked at the permacoll kits, not convinced on the hose clamps to hold the hose fittings. I can build a custom asy using peterson/permacool adapters and stainless braided lines for around $200. Still debating.
Thrust bearing on Kingpin wont fit. jason8374 1967 - 1972 F-100 & Larger F-Series Trucks 4 04-27-2015 08:01 PM
anyone close to seattle? jrockdiddy Washington Chapter 1 09-17-2014 09:17 PM
This is for jsnbuck mikeo0o0o0 1973 - 1979 F-100 & Larger F-Series Trucks 4 02-16-2013 02:13 PM
Fuel pump driver module? DANA60 2004 - 2008 F150 2 04-20-2010 09:48 PM
trailer tow lamp fuse #? wrenchturner 1997-2006 Expedition & Navigator 8 07-15-2009 11:19 PM
Tags
46, 46l, 98, coolant, coolent, cooler, cooling, engine, f150, ford, hose, line, lines, litre, oil, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
