block heater
Old 12-18-2005, 04:39 PM
scar98's Avatar
scar98
scar98 is offline
block heater
What's the easiest way to change a block heater in a 5.4?
Old 12-19-2005, 09:48 AM
MrBSS's Avatar
MrBSS
MrBSS is offline
If you are talking about the usual Ford accessory type, it is in a "freeze plug", normally on the driver side, low in the block. A toggle bolt holds it in. If you are planning to install a new one, you have to knock out the factory sheet metal plug.
