1999 F150 fuse configuration - heater - Ford Truck Enthusiasts Forums
Old 12-19-2005, 09:58 AM
stephenml stephenml is offline
stephenml is starting off with a positive reputation.
Heater blows cold air, there's no anitfreeze leaking into truck. Just wanted to check the fuses to see if there is a related fuse that might need replacing. Can't think of anything else short of taking it in to a mechanic. Pulled off fusebox cover but don't have an owner's manual that shows the configuration. Does anyone know if there is a fuse for the heating system and where it's located and the fuse rating? Thanks! Steve
Old 12-19-2005, 10:22 AM
Beast12's Avatar
Beast12 Beast12 is offline
Beast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant future
Hi and welcome to FTE! Be sure to read this to help you around this site: http://www.ford-trucks.com/forums/sh...d.php?t=300691 There are also State, Provincial and International Chapters located near the bottom of the main forum page.
We are glad to have you. Hope you enjoy the site. Check out the various forums. Lots of great info for you.
Thread moved to 97-2003 F-150 forum.
See ya on the boards!
-Matt
P.S. Here's an idea. Start the truck up and let it run for a while. Is the temperature gauge the normal area? Also, feel the radiator hoses. They should be hot. If they are cold or barely warm then it could be a thermostat that is stuck open. Good luck!
1972 Highboy, turn signal fuse blows, when heater is on Taylor Anderson 1967 - 1972 F-100 & Larger F-Series Trucks 3 10-24-2016 02:20 PM
Fuse box trouble NickOlsen53 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 04-13-2014 03:11 PM
98 F150 4.6 block heater fuse yellowsnakes 1997 - 2003 F150 6 03-05-2014 10:27 PM
block heater is blowing house fuse mknotts 1999 to 2016 Super Duty 12 01-05-2011 01:51 PM
93 Explorer fuel gauge not working, fuse? dareece Electrical Systems/Wiring 2 08-28-2003 12:54 AM
Tags
1997, 1999, f150, ford, fuse, fuses, heater, required, startiing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
