Go Back   Ford Truck Enthusiasts Forums > Misc. > Oil and Lubrication
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Oil and Lubrication NO MLM Dealers, Wholesale Buyers Or Retailers allowed (except sponsors)
SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 12-18-2005, 08:30 PM
xtrford xtrford is offline
xtrford is gaining momentum as a positive member of FTE.
Shell Rotella 0w40 synthetic in VW TDI
Anyone here running a 99-03 vw tdi? Time for a change in my wifes car and we usually get the german oil which is a 5w40 full synthetic, but I did notice at the local parts shop that the rotella is quite a bit cheaper and its deisel rated. My only concern is that when you read the back label it doesnt have the VW 505 api rating, from what I've been reading from this forum is that it's pretty good stuff, the 0 weight is appealling to me considering the cold weather up here in Canada so it would be nice if someone can give me more info on it.
  #2 (permalink)
Old 12-18-2005, 11:08 PM
Flash Flash is offline
Flash is gaining momentum as a positive member of FTE.
xtrford, here is your problem, your VW engine has known issues with being a sludge monster. Not just any oil is going to work. The Rotella T Synthetic I would consider as marginal for your engine. You may not have any problems at all with it but if it were my VW, I would be looking for Castrol Syntec in the GREEN bottle in 0w-30 only. This is not the usual Syntec so be careful as there is a black bottle which is more common and won't work. You are going to have to find a PAO basestocked oil that is at minimum diesel rated at CF. Mobil One in 10w-40 should be fine. Kendall Synthetic should be fine as well as Chevron or Havoline Synthetic. And if it just comes down to it, use Amsoil HDD oil or Mobil SUV oil. Those are are not the cheapest but is within the criteria for your engine.
  #3 (permalink)
Old 12-18-2005, 11:26 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog has a great reputation on FTE. ford390gashog has a great reputation on FTE. ford390gashog has a great reputation on FTE. ford390gashog has a great reputation on FTE.
you sure it was a 0w40???? as far as i know shell does not make a 0w oil only a 5w. it should have been 5w40 in a blue bottle.
  #4 (permalink)
Old 12-19-2005, 06:45 AM
wavinwayne's Avatar
wavinwayne wavinwayne is offline
wavinwayne is starting off with a positive reputation.
Flash,
Please allow me to correct a few errors in your post. Your statements are in quotes.
"xtrford, here is your problem, your VW engine has known issues with being a sludge monster."
It is the 1.8L Turbo gas engine in the Passats & Audi A4's that is the sludge monster, not the 1.9L TDI.
"I would be looking for Castrol Syntec in the GREEN bottle in 0w-30 only. This is not the usual Syntec so be careful as there is a black bottle which is more common and won't work."
Castrol Syntec 0w30 aka "German Castrol" aka "GC" is NOT, nor has it ever been in a green bottle. The bottles look exactly like all other Syntec bottles. It's the OIL that used to be green, from 2002-2005. Early in 2005, Castrol tweaked the formula, & now the oil is the same color as any other motor oil.
"Mobil One in 10w-40 should be fine."
The only Mobil One in 10w40 is their Extended performance oil. The 10w40 viscosity is almost impossible to find. Did you mean Mobil One 0w40?
__________________
I think I need some new toys.
  #5 (permalink)
Old 12-19-2005, 06:49 AM
wavinwayne's Avatar
xtrford,
Is your TDI a PD TDI? If it is, it requires a VW 505.01 approved oil.
If it is the non-PD TDI, then VW 502.00 or 505.00 or 503.01 approved oil will do the job.
BTW, Shell Rotella does not meet any of the above. However, I know of some folks who use Rotella T 5w40 in their non-PD TDI's with good success.
__________________
  #6 (permalink)
Old 12-19-2005, 07:45 AM
Thanx guys for your response, yes it is a tdi and the castrol syntec 5w40 is the other alternative for this motor but at a higher cost compared to the Volle-synthe german oil i usually get and the api is 505.01(thanx for correction wavinwayne). Looks like I'm stuck with expensive oil changes for the next little while, I was hoping the Rotella was going to adequate and it would have saved me a few pennies but oh well.
BTW ford390gashog, the Rotella was a 0w40 full synthetic and it came in a black 4litre jug with a light blue plastic wrap around it.
  #7 (permalink)
Old 12-19-2005, 09:13 AM
wavinwayne's Avatar
xtrford,
Without going into a bunch of detail, I'm a little confused by your posts.
Could you please post what your wife's VW owners manual states as it relates to the oil requirements?
Bottom line:
If your wife's VW is NOT a pump-duse TDI, then Rotella oil would work fine.
If your wife's VW IS a pump-duse TDI, then a VW 505.01 rated oil is the only oil you should use.
The owners manual will tell the tale on VW's oil requirement(s) for your wife's VW.
__________________
  #8 (permalink)
Old 12-19-2005, 03:09 PM
xtr
what were the specs on that rotella? CI4+/sl or older?
  #9 (permalink)
Old 12-19-2005, 09:14 PM
To answer your question wavinwayne it is a pump-duse tdi and does require the 505.01, sorry about the confusion, I can understand why when I looked at my last post.
ford390gashog, cant quite remember the specs on the back label but there was something about allisons and there was a CL rating but dont know what the exact number was, but I know for sure there wasnt anything related to the VW 505.01 spec. I'll let you know when I pay another visit to the store about its specific ratings.
  #10 (permalink)
Old 12-20-2005, 06:20 AM
wavinwayne's Avatar
xtrford,
One last thing; you said that Castrol Syntec 5w40 was an option for your wife's TDI. Castrol Syntec 5w40 IS NOT VW 505.01 approved.
If I'm not mistaken, Syntec 5w40 carries the VW 505.00 approval, which is a gasoline engine rating.
Castrol TXT 505.01 5w40 IS VW 505.01 approved.
ww
__________________
Tags
0w40 , 10w40 , 2000 , 2002 , 5w40 , amsoil , castrol , cost , passat , rotella , shell , sludge , syntec , synthetic , tdi , vw
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
