04 FX4 Tranny code - Huh?
from the ford website
Another improvement in the drivetrain is the use of the new 4R75E 4-speed automatic. The 4R75E is an evolution of the 4R70E that is used in the current F-150. The biggest changes are a faster computer, redesigned toque converter, addition of a turbine-speed sensor, “smart” shift control unit, and a fully sealed case filled with lifetime transmission fluid.
i think the sealed tranny is the stupidist idea ever.
A redesigned torque converter improves launch performance and increases efficiency.
-A turbine speed sensor improves transmission control, providing the basis for fully electronic shift scheduling to limit "hunting" and to fine-tune shift speed and feel.
-Increased microprocessor speed improves responsiveness and precision of the control system.
-"Smart" fully electronic shift scheduling knows what the torque will be in the next gear so it chooses the shift points based on the vehicle's projected performance in the next gear.
-Coupled with the electronic throttle strategy, the transmission computes the output torque required to maintain the vehicle speed, and chooses the correct gear and converter state accordingly.
-A sealed case and lifetime transmission fluid make the transmission maintenance free, while adaptive pressure control maintains consistent shift feel over time.
4r75e
so that means 4 gears
rear wheel drive
750 ft pounds max input torque
e is electronic
the tranny is plenty beefy to do what ever you want with it.
4r75e
rear wheel drive
e is electronic
Originally Posted by crazyriver
I have a 2005 FX4. I don't know about a filter in the transmission, but I do know that it has a removable pan and a dipstick. Just looked at it. The transmission code on the build sticker is "B". Anyone know if this is the 4R75E, or what?
It's got to be the 4R75e. My 04 also has the "B" tranny code, which is not even in the Owner's Manual. (!?)
I also have a dipstick and removeable tranny pan.
CMOS
[QUOTE=CMOS]It's got to be the 4R75e. My 04 also has the "B" tranny code, which is not even in the Owner's Manual. (!?)
CMOS, check your manual in the Maintenance and Specifications section, under Identifying Your Vehicle. In my 05 manual, it starts on page 301 and the transmission code designations are on page 302. Code B Four-speed automatic (4R75E)
[QUOTE=crazyriver]
Crazy - no kidding - my manual does not list the code "B" in that tranny table, nor is there any mention of the 4R75e. Weird....
CMOS
CMOS
CMOS
2009 - 2014 F150
02-27-2016 08:57 PM
CMOS
16
03-23-2015 07:24 PM
CMOS
12-13-2005 08:57 PM
