transfer case swap
Old 12-18-2005, 11:42 AM
Diamond Jim's Avatar
Diamond Jim
Diamond Jim is offline
transfer case swap
I have a 1995 F-150 5.0 e40d 2x4 and I was woundering if I could put a 1345 BW transfercase that was out of a 1989 F-150 with a M50d on to my e40d tranny and if not wat do i have to do. And Also would a transfer case from an 87 c6 bolt on. Thanks
Old 12-18-2005, 12:20 PM
johnsonswamp's Avatar
johnsonswamp
johnsonswamp is offline
No transfer case is a "bolt on" to a 2x4 transmission unless it is a divorced/free standing transfer case. You will need to get a 4wd tail shaft that's made for the E4OD to convert it to the 4x4 style, then most ford pattern transfer case's will bolt up.
Old 12-18-2005, 12:24 PM
Diamond Jim
what do u mean by divorsed/ free
Old 12-18-2005, 12:44 PM
johnsonswamp
Connected to the transmission by a very short drive shaft.
Old 12-18-2005, 12:46 PM
MustangGT221's Avatar
MustangGT221
MustangGT221 is offline
Theres two types of transfer case setups - one that is directly attached to the transmission (what most are) and ones that are not attached to the transmission. A divorsed transfer case is not directly mounted to the transmission, its separated.
Old 12-18-2005, 02:36 PM
Diamond Jim
the one that i have has an adapter bolted on the tc(1345) it was the one on the m50d the one on the c6 i've never seen yet.
joegeds
07-31-2014 06:02 PM
yfz 450
03-06-2013 06:26 PM
mrblonde108
09-23-2011 08:17 PM
Trykbos
08-09-2011 10:58 PM
LawF250
03-31-2010 01:20 PM
Quick Reply: transfer case swap
