British Columbia British Columbia
Join Chapter, Leader: sky Cowboy
I got an estimate
Old 01-28-2008, 02:14 PM
sedly's Avatar
sedly
sedly is offline
I got an estimate
I went and seen a couple guy's today about getting some body work done on my truck.I need to replace cab corner's,patch the floor and I figured while it's all geeting replaced may as well do the rocker panels.There is a guy a block and a 1/2 away from me who does good work,he say's it will take him a minimum of 40hrs. to do it.At $40.00 an hr.That seem's like an awefuly long time.The hourly rate is really good though.
Old 01-28-2008, 02:53 PM
mike240zt's Avatar
mike240zt
mike240zt is offline
Cab corners are actually pretty easy to do yourself. I have a Lincoln weldpak 100 I think it is. My brother did his last cab corner in about 2 hrs. welded in filled and primed. You can get floor pans and cab corners cheap enough and installing them isnt to big a deal. 1600$ is far to much to spend on a cab. You can get another cab in decent shape for under 300$. Myself I am just getting another cab because my current one is going to be more work than I want to do. (corners,floors,cab mounts, thin on the seams in the firewall) Picking my new one up tonight for a 100$ it's mint except for needing 1 minor patch. Basically I was looking for something for under 250$ that didnt need more than corners and/or floors. How bad are the rockers?
Old 01-28-2008, 03:11 PM
sedly's Avatar
sedly
sedly is offline
The rocker's aren't to bad but they should be done.The floor is going to be a simple fix,I don't need the whole floor pan.Just cut out a small chunk and replace.
Old 01-28-2008, 07:00 PM
Secret Agent 069's Avatar
Secret Agent 069
Secret Agent 069 is offline
When I worked for a body shop, I got my rockers done for free in the Mazda. But they got in behind, and put in some "peel and stick" light flexible aluminum, and then filled in the rest with bondo. After that, you couldnt tell where the rust posts were.
Old 01-29-2008, 06:46 PM
Zip's Avatar
Zip
Zip is offline
Ya that hourly rate is pretty good. Is 40 hrs a fair amount of time. To me it seems a little high. I am not a bodyman though.
Old 01-29-2008, 07:38 PM
Secret Agent 069
depends on how much rust, how bad the holes are. 40hrs sounds about right.
Old 01-29-2008, 11:22 PM
sedly's Avatar
sedly
sedly is offline
40hrs is way to much time.In my opinion.
Old 01-30-2008, 12:39 AM
Secret Agent 069
not if he is quoting, prep, work, and prep for primer & paint. If its just 40hrs for the work, then he's snorting too much bondo. If it is for everything, then 40 hrs is pretty damn good.
Old 01-30-2008, 12:43 AM
Zip's Avatar
Zip
Zip is offline
Can't you get replacement weld in replacement parts for all that stuff.
Old 01-30-2008, 12:45 AM
Secret Agent 069
rockers are really touph to weld in, easier and cheaper to lay in a coat or 3 of bondo.
Old 01-30-2008, 07:56 AM
sedly's Avatar
sedly
sedly is offline
The quote is just for the work.I had an estimate a few years ago for the same work,other than it was on my '81,$100.00 to do each rocker.I'm going to Ackland's this morning,I'm going to price out a mig welder.
Old 01-30-2008, 10:59 AM
Zip's Avatar
Zip
Zip is offline
I want to borrow it.
Old 01-30-2008, 06:05 PM
Secret Agent 069
They are a bunch of crooks then...
Old 01-30-2008, 06:34 PM
Zip's Avatar
Zip
Zip is offline
Have a few beers and fly at her sed. How tough can it be.
Old 01-30-2008, 08:52 PM
preppypyro's Avatar
preppypyro
preppypyro is offline
I bought a mig welder from an auction for 200 bucks or so. So far it does the job really well even though its not the highest quality welder out there.
Check on craigslist of you want a used one.
Quick Reply: I got an estimate
