Truck starts then shuts off or stutters - Ford Truck Enthusiasts Forums
Old 12-17-2005, 04:06 PM
79pos 79pos is offline
79pos is starting off with a positive reputation.
I have a 99 f-150 4x4 with a 5.4. I've had this truck for about a month now. Sometimes starting it up it will run for a few seconds then the rpms drop and it either cuts out and the rpms drop and pick back up. Other times they drop and the truck will shut off. I'm not sure what to do. I know almost nothing about the 97-03 trucks. I'm jumping up from a 79. This problem is really aggrivating me because of the money I just spent buying this thing. I appreciate any help given to fix this problem.
Richard
Old 12-17-2005, 05:49 PM
blue2golf's Avatar
blue2golf blue2golf is offline
blue2golf is starting off with a positive reputation.
If the engine light comes on, take it down to your local parts store(AutoZone, Advance, etc...) and they can hook up a scan tool to help diagnose your problem. If it's not throwing a code, it could be your Idle Air Control valve. About 2 months ago, my truck kept dying at idle engine speed with no engine light. I was powerbraking into work. I got some good advice about my IAC, swapped it out myself and now it purrs right along.
Old 12-17-2005, 07:37 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Yep, sounds like the IAC (Idle Air Control Valve). They seem to act up worse when it's cold outside. There is a good article in the READ FIRST FAQ thread at the top of the forum main page.
2000 7.3L Running Rough Xecular 1999 to 2016 Super Duty 0 07-15-2016 12:48 PM
2005 6.0 cranks but won't start! Padlock 6.0L Power Stroke Diesel 34 04-20-2014 11:30 PM
Driving in snow : mblanken881 2009 - 2014 F150 65 01-02-2010 08:47 PM
no rpms on gauges on a 93 7.3 idi Coalroller Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 01-02-2010 10:45 AM
Whys my oil pressure drop? truckman79 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 8 08-29-2003 09:06 PM
Tags
2001, 88, cuts, drop, engine, expedition, f150, ford, mustang, off, rpms, shuts, starts, startup, stutters, taurus, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
