how many miles will a 4.6L last?
  #46
Old 08-30-2006, 05:28 PM
DMch's Avatar
DMch
DMch is offline
My 1998 4.6L club cab with 8ft box has 321000k It has a warm up piston slap that is iritating, and need about 1/2 to 3/4 of a litre every 5000k. I have changed the oil and filter since I bought (her) new.
  #47
Old 08-30-2006, 09:17 PM
Mr.Novice's Avatar
Mr.Novice
Mr.Novice is offline
I understand using Lucas Oil Stabalizer helps with that. I read quite a bit of the thread on the piston slap and that's basically what I got out of it. No slap here, but I have a 4.6. Getting 16 MPG lately w/mixed driving!!!
  #48
Old 08-31-2006, 07:22 PM
one shot's Avatar
one shot
one shot is offline
I would look the rest of the the drive train over good, front end parts and such,i also own a 94 town car with 179000. it uses no oil in 2500-3000 mile services, the 4.6 is pretty tough...........
  #49
Old 08-31-2006, 10:05 PM
Big RedX's Avatar
Big RedX
Big RedX is offline
I have a 00 Excursion with a V10 which is pretty much the same as a 5.4/4.6 just add a couple cylinders. I bought it new and have 210k not a single engine or trans issue since new. The guys with rotting out heads, make sure when you change out your radiator not to mix tap water with the antifreeze. Used distilled or the pre mixed radiator fluid. Tap water has to many minerals and will rot aluminum heads. I'm sure that's why some are having head problems. Be careful most Jiffy lubes and oil change places use tap water to mix with their Radiator fluid. I change my coolant every 30k and have not had a single problem.
  #50
Old 08-31-2006, 10:16 PM
planemech's Avatar
planemech
planemech is offline
I have a friend who has a 4.6 in a 97' F150 w/150k and he was wondering if he should be worried about the amount of blow-by on his engine. It doesnt seem too bad to me but over a little bit of time I can see an issue of cleaning the intake of the oil. Do you think it is on its way out or is some of this "some what" normal and doesnt necessarily mean the engine has a limited life left? He does say though that it only uses about a half qt. every 3500 miles. What should I tell him?
  #51
Old 09-01-2006, 06:13 AM
Big RedX's Avatar
Big RedX
Big RedX is offline
Have him check his PVC valve.
  #52
Old 09-06-2006, 04:02 PM
Fosters's Avatar
Fosters
Fosters is offline
Originally Posted by geoaigel
I don't think SOHC vs. DOHC will make a difference, if the engines are treated in the same manner. Unfortunately, in average, I would guess the Mustang engines get beat on a lot more than your average daily driver truck.
George
I have a dohc mustang and a sohc truck (as of yesterday ). I highly doubt the mustang will outlive the truck, not because of the way it was built, but the way it is driven... the mustang will see 7000+ rpm a lot more often than the 5.4 in my truck, and in general a v8 mustang will be put through it's paces more than a truck... sure it may not tow as much and whatnot, but high RPMs will kill an engine faster than anything unfortunately...
zman:
With the scenario you describe, it probably doesn't make a huge difference. But we are talking over-revs, mis shifts, neutral drops and other stupid stuff on a mustang, not driving it performance oriented within it's designed range. That said, once your head gasket is letting go, it will do so much quicker at higher combustion chamber pressures (wide open throttle and towing) than when you "baby" the vehicle.
Cheers, George
even within their respective designed range, just the fact that the truck will be wound up at most 2000 rpm less than the mustang, it'll make a huge difference on the life of the engine... Forged crank or not, in the end, they use the same crappy hypereutectic pistons and powdered rods... pistons are doing all the friction, and they will be hurting a lot more pushing 7200 rpm than a truck/crown vic that rarely ever sees 5000...
  #53
Old 09-22-2006, 01:57 PM
misterfisher's Avatar
misterfisher
misterfisher is offline
Longevity
Originally Posted by pfogle
Think about this. Ford started putting the 4.6 in the Crown VIcs in 92 or 93, how many taxis are there out there? Most of them have over 400k on them... I'd say 160k isn't a problem.
A buddy of mine who back-yard wrenches for a local cab company pulled a 4.6 out of a Crown Vic with 600,000 KM on it. It ran, but was a little hard to start. I should say it ran, used a little bit of oil, and this is with EVERY ring in the thing broken. The bearings looked like new, everything else looked good except the rings.
  #54
Old 09-22-2006, 02:08 PM
Mr.Novice's Avatar
Mr.Novice
And I feel bad when my RPM's get to 5,000... My truck really hates that. I try to keep it under 2,300 or so.
Oh, and 600,000 miles is a lot for only having bad rings. How about that?
  #55
Old 09-22-2006, 03:32 PM
misterfisher
Miles
It was 600,000 KM (Kilometers), that's what we metric guys use up here in Canada eh! That translates into around 380,000 Miles.
  #56
Old 09-22-2006, 03:40 PM
Mr.Novice's Avatar
Mr.Novice
600,000 km is still a lot of miles
  #57
Old 09-23-2006, 09:30 AM
Edmund Flash's Avatar
Edmund Flash
Edmund Flash is offline
glad to hear about the long life of a 460 motor'
i just got a 74, f-150 with a 460 motor c6 trans, - truck had full size in bed camper on it and only has 95,548. miles on it
so im glad to hear about the long life'' cause i,m driving this old girl a long time'''
  #58
Old 09-24-2006, 03:16 PM
skilife17's Avatar
skilife17
skilife17 is offline
Just last Tues my 97 F150 4.6 turned over to 190000 Miles. Still running strong, doesn't burn oil.
  #59
Old 09-25-2006, 01:17 AM
Ohiostomper's Avatar
Ohiostomper
Ohiostomper is offline
I have a '97 with the 4.6 that I bought new. It has been a pos since the day it came off the showroom floor. It died at 98k miles and had to be completely rebuilt. Just a few weeks ago it started knocking again at 165k. I have a '95 thunderbird with the 4.6. 120k and it drops oil pressure and knocks every now and again. Also have a 97 psd with 310k on it. I really believe it is luck of the draw. I got a few lemons. If you are "lucky" you may find a truck where 160k isn't too bad. My advice is to save your money a while longer and find one with lower miles. You will always see the good trucks with the high miles. Why would you see the bad ones? They are in the junk yards. I love Ford, but I don't see the 4.6 as a high mileage engine. At least with my experiences.
  #60
Old 09-25-2006, 08:48 AM
Mr.Novice's Avatar
Mr.Novice
Just out of curiousity, Ohiostomper, but what kind of work does your 97 do? Meaning do you tow/haul a lot or is this your daily driver? What kind of oil do you use and how often do you replace it?
Quick Reply: how many miles will a 4.6L last?
