460 engine weight
Old 01-01-2002, 08:26 PM
Sedric's Avatar
Sedric
Sedric is offline
460 engine weight
How does the weight of a 460 compare with a 360/390 or a 302. My shop manual refers to a 460 as a "light weight design". I see a lot of people putting 460s in place of 302s...would the front springs have to be upgraded?
Old 01-01-2002, 08:55 PM
bluepony79's Avatar
bluepony79
bluepony79 is offline
460 engine weight
Old 01-01-2002, 09:15 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
460 engine weight
Someone posted the weight of the 429 a little while ago as they were either shipping one or having one shipped.
They are heavier than the 390 and a lot heavier than a 302.
When I swapped in my 429,I did the front springs shortly afterward,basically because they needed doing.
https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=768&.jpg
Dennis
Please Don't Ask Me Any Tough Questions As:
"I'm Saving Up MY Memory For When I Develop Alzheimer's"
78 F-150 429CJ C6 ,Silver w/Explorer Pkge
641/2 Mustang,Pre-World's Fair Car #8092
64 Fairlane S/C waiting for a 390-4spd.
68-Mustang.Sunlit Gold 80,000 miles
Old 01-01-2002, 09:22 PM
bluepony79's Avatar
bluepony79
460 engine weight
If you don't stabilize the front end, the extra weight will eventually wear out your front end(been there, done that) till the front tires literally toe in .
Old 01-01-2002, 09:56 PM
Matt67's Avatar
Matt67
Matt67 is offline
460 engine weight
[updated:LAST EDITED ON 01-Jan-02 AT 11:02 PM (EST)]Ford Engine Weights in pounds
221-302W = 460
302 Boss = 500
351W = 525
351C-Boss = 550
351M-400 = 575
332-428FE = 625
427 HEMI = 680
429-460 = 720
429-Boss = 635
This should help you out. :P
Old 03-12-2009, 09:55 AM
chris 70 f100's Avatar
chris 70 f100
chris 70 f100 is offline
so if i put a 460 in my f100, i would have to go leaf springs instead of coils because of the extra weight
Old 03-12-2009, 10:07 AM
Pickupmanx2's Avatar
Pickupmanx2
Pickupmanx2 is offline
NOPE, you can find some beefier coils, you do not want to go to leafs,,, I bought lift coils for my 77 F150 4x4 for about 125 to handle the extra weight of bumper winch and possible 460, about $125 for a pair.
Old 03-15-2009, 11:34 PM
hairyboxnoogle's Avatar
hairyboxnoogle
hairyboxnoogle is offline
Im putting a 7.3 in my 79..... 1200 lbs
Old 03-16-2009, 12:13 AM
Ranger76's Avatar
Ranger76
Ranger76 is offline
just get some coils from an f-250 that was equiped with a 460, that should work just fine.
Old 03-16-2009, 01:36 PM
hairyboxnoogle
F-150 and F-250 have the same coils. There is the standard coil, and an HD coil. F-150s with 460s had HD coils. And all F-250s had HD coils. THere are some variances im sure but thats the short and simple of it.
Personally... id pick up some leveling coils... 150- 200$ and if anything it will sit more level and carry the weight just fine. Im pretty sure all aftermarket coils have the same pounds per inch rating as the HD ones or heavier.
Old 03-24-2016, 01:33 AM
Thunderhorn's Avatar
Thunderhorn
Thunderhorn is offline
Id have to agree with what has already been said. For sure need to upgrade suspension but no need to go leafs unless you really want to. You see those King of the Hammers trucks blowing up boulders with coils and fully independent suspension for that matter. it all really comes down to how much coin you're willing to spend. Not upgrading weight capability in SOME way would be a bad idea in this case.
Old 03-29-2016, 06:04 PM
PA74F250's Avatar
PA74F250
PA74F250 is offline
Hmm it's only been about 7 years I wonder what he decided
Old 03-29-2016, 06:55 PM
flowney's Avatar
flowney
flowney is offline
Probably something he didn't want to talk about.
My '77 F-250 Camper Special had a 460/C6 in it and I'll be putting that in a '76 F-100. I'll save those springs until I find a CV IFS from a cop car. Just in case.
Old 03-29-2016, 11:50 PM
privateer, eh's Avatar
privateer, eh
privateer, eh is online now
Hey, at least I found out that my 460 is 720 pounds, with zf transmission, accessories and radiator it must mean that it's going to be a heavy lift for my engine hoist. anybody ever do a tail shaft to rad lift. It's coming out of a truck thats getting cut up for scrap so I'll be cutting the frame so that it's out of the way, chopping off the rest of the cab tomorrow
Old 03-30-2016, 06:44 AM
co425's Avatar
co425
co425 is offline
Shouldn't be a problem. Just use a load leveler to level the lift.
Quick Reply: 460 engine weight
