Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 401, 477, & 534 SD Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 12-15-2005, 08:18 AM
cdrmckinneybb63 cdrmckinneybb63 is offline
Garage is empty, add now
cdrmckinneybb63 is starting off with a positive reputation.
can a 477ci go into a 79 f250 or a beefup f150
hi, i just got a 477ci gave to me and it was rebuilt plus trans and i like to know if it can go in to my 79 f250 or can i put it in to my beefup 79 f150, both trucks had a 351m in before and both are 4x4 also, hope someone can help.thanks gene,
__________________
gene/brenda mckinney
  #2 (permalink)
Old 12-15-2005, 06:10 PM
Kruse Kruse is offline
Kruse is gaining momentum as a positive member of FTE.
Quote:
Dear Lord, give me strength........
Okay, just kidding about the sarcasm, but that's what your F250 or F150 will be saying if you ATTEMPT to put that motor in. The 477 weighs about 1300 pounds. That's about 800 pounds more than your 351M. How long will the front end of your truck last?
The 477/534 is also a very low RPM motor, 3300 max. Gas mileage is about 3 miles per gallon and NO speed parts are available.
Stick with your 351, or if you absolutely need the cubes, drop in a 460. Good as it was, the 477/534 is an antiquated motor that Ford stopped building for a reason.
  #3 (permalink)
Old 12-16-2005, 12:46 AM
pfogle's Avatar
pfogle pfogle is offline
pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.
patfogle DaPocky
They are slow revving torque monsters. Unless you like pulling a house and going slow the 477 is not for you.
__________________
1996 F150 Regular cab, SWB, 4.9. 5speed.
- Life is like a roller coaster, Live for the ups.
- Negativity begets hate, hate begets ignorance, ignorance begets stupidity. Don't be stupid.
- If you have to ask "Will this hurt?" do not proceed!
  #4 (permalink)
Old 12-16-2005, 01:14 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
the simple answer is no. the SD engines weigh a tad bit over 1,100 lbs. which is about 400 more than a 460.
  #5 (permalink)
Old 01-04-2006, 08:17 PM
cornfeed cornfeed is offline
cornfeed is starting off with a positive reputation.
I would love to see someone actually try it. It may not be smart and it wouldn't be easy but you'd have the only one around. I love the 477 in my LT 800. I get 5 mpg in a 17,000 lb truck loaded to 33,000 1/2 of the time.
Good Luck
__________________
1951 f5 239 flathead
1959 f100 4x2 223
1974 f100 4x4 390
1975 f150 4x2 390 4bbl
1978 lt800 dump truck 477
1989 f150 cummins 4bt
1993 f150 4x4 302
1997 f700 429 LP
2000 taurus 24v DOHC 3.0
Tags
477ci, diesel, engine, ford, gas, spec, torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
