98 ford bumper
Old 12-13-2005, 09:39 PM
chucky79's Avatar
chucky79
chucky79 is offline
98 ford bumper
Hey guys just wondering if the 99-03 bumper will fit on the 97-98 trucks. i like the look of the newer ones better than mine, not to mention mine has a big dent and i was gonna replace it and would like to upgrade as long as its simply a bolt on. thanks.
Old 12-13-2005, 09:44 PM
flatrate's Avatar
flatrate
flatrate is offline
if you are talking front bumper, then no it wont. im not sure about the rear---it should fit---but not sure. you might be able to change the whole headlight/ grill piece and do a later bumper....just not sure
Old 12-13-2005, 10:12 PM
Smaug's Avatar
Smaug
Smaug is offline
simple swap, just did it to mine a few months ago. Here's the parts list
------------------------Normal F-150 Front-End Upgrade------------------------
(1) 1999-2004H Grille Shell
(1) 1999-2004H Left Grille Shell black plastic deflector
(1) 1999-2004H Right Grille Shell black plastic deflector
(1) 1999-2004H Bumper
(1) 1999-2004H Left Bumper Brace
(1) 1999-2004H Right Bumper Brace
(1) 1999-2004H Left Bumper-to-Frame Mounting Bracket
(1) 1999-2004H Right Bumper-to-Frame Mounting Bracket
(1) 1999-2004H Bumper Top-Pad
(1) 1999-2004H Bumper 2WD Bottom Air Dam
---------------------or--------------------
(1) 1999-2004H Bumper 4WD Bottom Air Dam w/ Fog Lights
Old 12-19-2005, 09:11 AM
mat-helm's Avatar
mat-helm
mat-helm is offline
Just to clarify 97-98 Fog lights and brackets are different from 99-03.
Nice list Smaug, where were you a year ago when I needed it. lol
Old 12-19-2005, 03:42 PM
preppypyro's Avatar
preppypyro
preppypyro is offline
Those bumper to frame mounting brackets, what exactlyare those, and how do they fit? Do they bolt on direct?
Old 12-19-2005, 06:07 PM
mat-helm's Avatar
mat-helm
mat-helm is offline
Looks like a fat X. There are brackets welded to the frame which the bumper brackets bolt to(2 bolts each side). Those brackets (which are different 97-98 to 99-03) are what the bumper bolts to (4 bolts each side).
Old 12-19-2005, 06:51 PM
preppypyro's Avatar
preppypyro
Ahh ok, Because someone changed the grill on my 97, to a newer grill, but not the bumper, so I am going to change the bumper over, just wasnt sure all what was involved.
Old 12-19-2005, 07:02 PM
mat-helm's Avatar
mat-helm
mat-helm is offline
Yea.. I think I remember a pic of that about 10 months ago. Expidition grill, right?
Old 12-20-2005, 11:31 AM
mat-helm's Avatar
mat-helm
mat-helm is offline
Smaug, I just noticed 2 things on your list that are not needed:
97-98 will work fine with the 99-03 "Bumper Braces"
As will the:
Old 12-20-2005, 08:40 PM
preppypyro's Avatar
preppypyro
Yeppers man you got er, expedition grill. I bought it liek that, so I want to change it over sometime soon so it looks better.
Old 12-20-2005, 09:18 PM
Smaug's Avatar
Smaug
Smaug is offline
As will the:
I did trim my deflectors down to fit but the brackets have different part numbers.
Old 12-21-2005, 08:50 AM
mat-helm's Avatar
mat-helm
mat-helm is offline
Smaug, What did you use to connect the upper pad to the bumper? My parts guy showed those little "thing-a-majigs" to retail for almost $5 bucks a peice x 11 of em.
Old 12-21-2005, 04:42 PM
Smaug's Avatar
Smaug
Smaug is offline
Local dealer wanted $7 ea., I used 3/8 in bolts. Got 'em free from work. Haven't had any of them loosen up yet.
Old 12-21-2005, 04:52 PM
mat-helm's Avatar
mat-helm
mat-helm is offline
Bet that was hard to tighten huh... I used some extra large (5/16) black push in type plastic pins (like the ones used on the plastic deflectors, and some 5/16 star lock washers.
Old 12-21-2005, 09:11 PM
Smaug's Avatar
Smaug
Smaug is offline
Was hard to tighten but I could get a pr of needlenose on most of them. Wish I'd thought of your idea though.
