diesel fuel fired block heater
Originally Posted by jessejames88
i'm trying to find one now cause my pig wont start in 40* its pittiful...
You might start by fixing the glow plug system. It should easily start at 40°F. I've started mine in the low teens (unpluged) without issue, though I'd normally plug it in below freezing. Unless you frequently need to start away from an outlet and/or in really really cold weather working glow plugs and the stock block heater seem quite sufficent. Even working glow plugs without the blockheater is sufficent for any temp's my truck has seen.
Is this a standard IDI we are talking about? I know a lower compression engine can be harder to start cold, but the IDI's should fire right up with good glow plugs.
Also, what weight oil are you running? I imagine a really thick oil could slow things up enough to be a problem. I run 5w-40 Rotella synthetic stuff.
good luck
good luck
yeah i was origonally just posting about the diesel fired coolant heater just thought i'd vent some of my fustration about my psd while i was here but yeah it starts if its plugged in has a slight misfire... for about 30 minutes but when i'm nyc in my apt and at work plugging in is not an option when i'm home in upstate ny the temps get pretty extreme not unusual for -0 temps in jan feb and like i said no start today in 40 deg temp
Update
I got 8 Dualcoil plugs from ebay (had to change the harness ends to female spade clips), put a new starter in too. Starts much easier now, I fire the plugs for 25 seconds on a manual switch, the new starter spins it like a gasser and Vroom! No more crossed fingers at -20F. I also got a propane fired block heater from ebay but I have not installed it yet, likely once it warms up. Also thinking of following Zigg's homemade propane inject now that I'll have another reason to carry a gas bottle.
Europeans all have these things, and for the most part they don't need them. I had a 4 banger diesel mitsu van in Germany with one, I wish I had taken the webasto heater out of it when I sold it. A bit of laziness prevented me, kicking myself now. It generated 5K watts and had its own 12V coolant pump, timer, and now they come with a remote. At 20 degrees it got that 4 cyl up to operating temp within 20 minutes. They sell here for $1500 where you can get them.
kawcrasher
02-05-2007 05:34 PM
