Electronic ingnition for a 534
Old 12-12-2005, 05:02 PM
marspenc's Avatar
marspenc
marspenc is offline
I have decided to keep the 534, for now, in my c950, however does anyone know if there is a distributer that can replace what is there to get rid of the points? and, what it would take to add electronic ignition? Also, I would love to hear any stories on the Holley Projection - Does it worlk well? Is it worth looking into for increased gas milage?
Old 12-12-2005, 06:33 PM
Kruse's Avatar
Kruse
Kruse is offline
I would check to see of the Pertronix unit is available for your year and model. I've installed some on some Ford units and it really helps. If the catalog doesn't show an application for your year and model, find a mom and pop auto parts store that will do the extra leg work for you. I recently found one that fits a '50 International pickup and also another for a Wisconsin V-4 engine, two applications that do not show up in any application catalog.
The Holley Projection unit is probably doable, but would take a lot of garage engineering.
Old 12-12-2005, 07:01 PM
Louisville Joe's Avatar
Louisville Joe
Louisville Joe is online now
Remember that Super Duty's from the mid-70's had Duraspark electronic ingnition. You might look into buying a rebuild distributor for a later version, along with a module. As I remember, Pertronix does make a kit for these as well.
Old 12-12-2005, 09:54 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
crane cams sells the xr-i setup with rev limiter for 72.00 fits all fords with single point from 59 to 74. try www.summitracing.com
Old 12-19-2005, 02:45 PM
marspenc's Avatar
marspenc
marspenc is offline
Thanks guys- I'll look into a later model. That seems like the easiest option.
6t56
401, 477, & 534 SD Engines
06-09-2020 03:31 PM
deere81
02-05-2018 08:49 AM
trward79
13
04-26-2017 03:17 PM
beegeezy
29
10-05-2006 08:13 PM
beuford79
General Automotive Discussion
03-18-2004 04:09 PM
Quick Reply: Electronic ingnition for a 534
