can a 477ci go into a 79 f250 or a beefup f150
Old 12-15-2005, 08:18 AM
cdrmckinneybb63's Avatar
cdrmckinneybb63
cdrmckinneybb63 is offline
hi, i just got a 477ci gave to me and it was rebuilt plus trans and i like to know if it can go in to my 79 f250 or can i put it in to my beefup 79 f150, both trucks had a 351m in before and both are 4x4 also, hope someone can help.thanks gene,
Old 12-15-2005, 06:10 PM
Kruse's Avatar
Kruse
Kruse is offline
Dear Lord, give me strength........
Okay, just kidding about the sarcasm, but that's what your F250 or F150 will be saying if you ATTEMPT to put that motor in. The 477 weighs about 1300 pounds. That's about 800 pounds more than your 351M. How long will the front end of your truck last?
The 477/534 is also a very low RPM motor, 3300 max. Gas mileage is about 3 miles per gallon and NO speed parts are available.
Stick with your 351, or if you absolutely need the cubes, drop in a 460. Good as it was, the 477/534 is an antiquated motor that Ford stopped building for a reason.
Old 12-16-2005, 12:46 AM
pfogle's Avatar
pfogle
pfogle is offline
They are slow revving torque monsters. Unless you like pulling a house and going slow the 477 is not for you.
Old 12-16-2005, 01:14 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
the simple answer is no. the SD engines weigh a tad bit over 1,100 lbs. which is about 400 more than a 460.
Old 01-04-2006, 08:17 PM
cornfeed's Avatar
cornfeed
cornfeed is offline
I would love to see someone actually try it. It may not be smart and it wouldn't be easy but you'd have the only one around. I love the 477 in my LT 800. I get 5 mpg in a 17,000 lb truck loaded to 33,000 1/2 of the time.
Good Luck
54Hydro
10-24-2016 04:37 AM
76f250460
Large Truck
06-06-2014 08:27 AM
F1truckproject
06-18-2013 01:57 PM
PCTVFD
401, 477, & 534 SD Engines
04-22-2008 11:36 PM
Rupturedduk
1978 - 1996 Big Bronco
06-04-2005 10:00 PM
Quick Reply: can a 477ci go into a 79 f250 or a beefup f150
