Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 12-12-2005, 04:14 PM
blueheal blueheal is offline
Garage is empty, add now
blueheal is starting off with a positive reputation.
Jet Fuel
I recently purchased my first diesel truck and was wondering if I could use Jet Fuel in place of diesel fuel. I heard it was good for cleaning the injectors and was equivalent to a high grade diesel. I just want to use it every six months or so or when it is cold outside.
  #2 (permalink)
Old 12-12-2005, 06:41 PM
cookie88's Avatar
cookie88 cookie88 is offline
2001 Ford F-250
cookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant future
f250juggernaut
Welcome to Ford Truck Enthusiasts blueheal.
There are plenty of addatives available for our diesels that lower the cloud point and clean the injectors without sacrificing the lubrication properties that keep our injectors and IP's running smooth and quiet.
Jet fuel is not a high grade diesel, it's a high grade kerosene. Makes a good solvent, but power and performance will suffer.
__________________
Scott
His: 01 F-250 Lariat, 7.3, ZF-6, NV271. A few mods
Hers: 06 Freestar SEL 4.2l
79 Bronco Ranger XLT.. used be the driver, now waiting to become the project.
96 Grand Marquis LS... 25 mpg commuter
  #3 (permalink)
Old 12-12-2005, 06:43 PM
fgtex fgtex is offline
fgtex is starting off with a positive reputation.
The Marines, maybe all the military, use jet fuel in their various diesel engines nowadays without any modifications. They are trying to go to a single fuel for all equipment. I am no mechanic, but I've heard that they are similar in some respects. I think I've heard that the fuel filter has to be changed more often, but I am not sure.
Here is a link talking about the military's Single Fuel Concept.
http://www.globalsecurity.org/military/library/report/2005/050300-concept.htm
  #4 (permalink)
Old 12-12-2005, 07:22 PM
AFSOCmech AFSOCmech is offline
AFSOCmech is starting off with a positive reputation.
There is a method to using jet fuel (JP-8) in diesel engines. It involves adding oil to the fuel, although I'm not sure of the ratio. I'm on the jet engine mechanic side of things. If I remember correctly what I was told, the jet fuel tends to wash down the cylinder walls depriving the rings of proper lubrication.
I don't know if it matters as much, but on the C-130 aircraft, the engine start temperatures are considered good if it reaches 820 degrees celsius and are limited to max out at 1070 degrees celsius. I'm not saying you would encounter that in a diesel engine, but just think if you did.....
  #5 (permalink)
Old 12-12-2005, 10:43 PM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Thumbs down Jet fuel
Right on the money Scott! Kerosene has very little lubrication value, It will EAT up IP's and injectors. I've worked on Army multifuel engines, they are completely different than the diesels we drive. FABMANDELUX
  #6 (permalink)
Old 12-12-2005, 10:45 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
you cannot compare the military diesel engine to yours. they are very different. you need to run regular diesel.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
