2.3 Head swap info - Ford Truck Enthusiasts Forums
2.3 Head swap info
Old 12-12-2005, 04:14 PM
buckeyes903 buckeyes903 is offline
buckeyes903 is starting off with a positive reputation.
Exclamation 2.3 Head swap info
Does anybody know if you can swap the new DOHC onto a 94 2.3 SOHC engine?? or what is a good head to put onto it to make more power?
Old 12-12-2005, 06:48 PM
AlfredB1979 AlfredB1979 is offline
AlfredB1979 is starting off with a positive reputation.
Port and polish what you have.
The new DOHC head isn't eve close to a match-up. The Volvo DOHC head talked about on turboford.org(?) isn't a straight shot, either.
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1979, 20, 23, bar, conversion, dohc, engines, ford, head, headswap, interchange, sohc, swap, sway, volvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
