1988 E-350 Cabriolet
This truck was designed to pull a 5th wheel camper or trailer. I bought it to restore and pull a hot shot trailer with. It had an exhaust leak when I bought it which I thought would be no problem. I have since found out that the 460 had a problem busting exhaust manifold bolts or cracking the manifold. I found that it had 3 busted bolts on one side and 2 on the other. I had to pull the heads to get the busted bolts out and when I put it back together I do not want to have to do it all over again. I wonder if there is anyone out there that has had this problem with the 460 and what they did to fix the problem. You can e-mail me at DGMC1979@woh.rr.com Any help will be very much appreciated! Thanks Don! ()) ())
...Welcome to Ford Truck Enthusiasts!
If you get a minute check out the link here, it will help you to navigate around and understand this site.
https://www.ford-trucks.com/forums/s...d.php?t=300691
We are happy you have chosen the best source for Fords!
Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
See you on the boards. ….
It came from the factory with stainless bolts. We were thinking that stainless was just too hard and might have been part of the problem. Do you think if we put a copper exhaust manifold gasket in there to give a little room for expansion and contraction. Let me know what you think. It is so hard to do any thing in that van we want all the input we can get. Thanks ()) ())
Big-old-460
314
09-21-2016 10:38 PM
PDX_350
11-09-2013 01:13 AM
MikeS29
22
07-19-2010 09:01 AM
