2003 Super Duty - V10 - Ping/Spark Knock - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 03-01-2006, 10:53 PM
68 351 bronc 68 351 bronc is offline
68 351 bronc is starting off with a positive reputation.
mdpopo59, You say that removing these deposits cannot harm your engine, they are disolved and blown out though your exhaust system.
The solvents that are strong enough to desolve carbon in a solid form will destroy the lubricating properites of oil imidiantly and as the piston moves up and down this mixture of extremly abrasive carbon and oil desolving solvents will be the equivelent of running your engine without oil for and extended period of time without an air filter in a sand storm. The piston to bore clearance will not be the same when you are done. Do to the loss in compression you will not have to worry about predetination any longer.
MD, do a compression check of each cylinder. I'll bet you will find it lower than it should be.
There is NO WAY I would do this to my V-10 or any engine that i gave a **** about!
  #47
Old 03-02-2006, 06:08 AM
mdpopo59 mdpopo59 is offline
mdpopo59 is starting off with a positive reputation.
I don't know about your engine, but mine does not use oil to lubricate the piston chamber. These slovents are present in every gallon of gas you buy to a certain extent, depending on the brand, AND in you motor oil you use. It is through the use of these solvents that you keep you engine clean. The carbon deposits are not present as much on you piston as they are around your valves. A name brand gasoline with a large amount of "solvent" additives can help prevent this condition but will not clean a large amount of buildup.
But you're right, if you can keep your engine clean enough to keep from having to do this that would be best. But if you already have this condition then there will probably come a point where the high octane gas will no longer mask this condition.
  #48
Old 03-02-2006, 09:15 AM
DJR 17's Avatar
DJR 17 DJR 17 is offline
DJR 17 is starting off with a positive reputation.
mdpopo59,
your last reply sounds like it might be my situation to a tee. I have been running super for years now and even with super I sometimes hear a little bit of pinging. I have 165000 miles now and never had the intake cleaned or fuel system flushed. What would you reccomend would be the best thing to do?
  #49
Old 03-02-2006, 09:18 AM
Krewat's Avatar
Krewat Krewat is online now
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Quote:
I think someone needs to go back to the basics and re-learn what lubricates the rings
Oil DOES get on the cylinder walls and lubricates the rings and piston as it slides up and down. Too much solvent washes the oil off and RUINS the rings and cylinder walls.
This happens when there is too much gasoline too - as in too rich, and you'll wipe out the cylinder walls.
I think removing carbon any other way than taking off the top end of the motor is an accident waiting to happen.
But what do I know?
  #50
Old 03-02-2006, 11:18 AM
Five0guy Five0guy is offline
Five0guy is starting off with a positive reputation.
Quote:
Originally Posted by DJR 17
mdpopo59,
The real downfall to running the preminum for years that you might not be able to go back with out doing a major top end cleaning.
  #51
Old 03-02-2006, 11:26 AM
PurerockRacing's Avatar
PurerockRacing PurerockRacing is offline
PurerockRacing is starting off with a positive reputation.
if there was that much carbon build on the combustion chamber to cause the engine to ping, would that also show up on the plugs? There should also be alot of carbon on the plugs as well I would think. I pulled 4 of my plugs, 2 from each side, and the plugs look like brand new still. Perfect color, no deposits or funny looking stuff on them at all. Most likely they are the original motocraft plugs with approx. 48k miles on them so far
  #52
Old 03-02-2006, 05:02 PM
Krewat, that explains it well.
Also, how long will it take to run all of the solvent out of this vacume line? How much will seep past the top ring while it is sitting?
Once a piston skirt or cylinder wall has been scored the engine won't have many miles left.
  #53
Old 03-02-2006, 05:35 PM
Krewat's Avatar
Quote:
Depends on the heat range of the plug, and how far off it's "ideal" temp it was running to begin with.
Using cheap gas with no (or not much) detergent is the more likely factor.
Maybe that "high octane" has no cleaning additives in it? At least for people who've developed "octane dependency" ???
  #54
Old 03-02-2006, 08:15 PM
Krewat,
You're right about oil lubricating the rings. I guess what I was trying to say is that, gasoline being a natural solvent, would automatically wash any oil off the piston wall during each piston cycle, wouldn't it? And your also right that the best way to clean these deposits would be to remove the heads. Same goes for the intake manifold.
Just speaking from my personal experience, I have been using this method for the last 20 years and have had several of my vehicles between 100 and 150 thousand miles with no problems with oil usage or compression issues. I'm not saying that nothing can go wrong, I've just never seen an issue.
I don't want to mislead anyone that I think I know it all, I don't. I just want to help other people the same as I have been helped through this forum. I guess it all boils down to the fact that each person has to take what they read here and make a decision for themselves.
BG has an intake/injector cleaning kit that my mechanic uses. It comes with a throttle body cleaner you spray into the intake manifold, an injector cleaner you run through the fuel rails, and another cleaner you put into your gas tank. I know that this system works well and BG gaurantees it.
Just one question, what is that schrader valve on the fuel rails for? I always thought it was there specifically to run a cleaner through the fuel system and injectors, but obviously I have been known to be wrong before.(Don't everyone agree at once)
  #55
Old 03-02-2006, 10:05 PM
Krewat's Avatar
One of it's functions is to check the fuel pressure. I can't imagine doing that without the schrader or some other valve right there
Otherwise, I agree with you, except I'll never do it myself
  #56
Old 03-03-2006, 01:07 PM
DJR 17's Avatar
Could a bad COP cause a ping? Or do these usually fail completely? I had a problem yesterday with the truck sputtering at 1/2 to full throttle. I was pulling away from a stoplight and it started after about 15 feet away from the light. If one cylinder wasn't firing due to a COP would that cause the engine to sputter? The truck runs fine this morning??
  #57
Old 03-03-2006, 01:26 PM
Krewat's Avatar
It wouldn't cause a ping...
That sputtering could be a COP or the MAF needs to be cleaned. Depends on what happened.
Get it to a shop to get the misfire counters read and go from there.
  #58
Old 03-03-2006, 02:49 PM
tjv01excursion tjv01excursion is offline
tjv01excursion is starting off with a positive reputation.
I am wondering if my PCM is bad because my truck runs fine just spark knocks. No codes have ever showed. I am considering changing the thermostat to make sure it does not have the incorrect one in it. It doesn't knock until it gets up to temp which is exactly half on the gauge. My Excursion runs a little lower than that.
  #59
Old 03-03-2006, 03:04 PM
Krewat's Avatar
Quote:
I wonder if the knock sensor input on the computer is bad? But then, it would log a code because it wouldn't "see" it (or should).
Guys, is there any way for a knock sensor to fail in a way that the computer doesn't see any problem?
  #60
Old 03-03-2006, 04:01 PM
If the timing is set too far advanced it will cause pinging under load and on acceleration. I don't believe there is any way to adjust the advance on the timing with these engines, other than changing the computer settings. Charlie Captchas asked earlier in this post about "tuners". One way that tuning programs gain horsepower in these engines is to advance the timing. I know some of these tuning manufacturers specify 89 or 91 octane fuel just for this reason, to prevent the pinging.
Everyone here has touched on the various other devices that may go bad and create a problem, up to and including the PCM. I had a '94 F-150 5.0 once that had the O2 sensor go bad and the PCM did not throw a code. I currently have a Windstar that periodically throws a code and nobody has been able to figure out for what or why.
Can't Get Rid of Spark Knock capnbass91 1968-2013 Full Size Vans 11 02-16-2017 04:14 PM
1988 F150 4.9L Engine dies after warm UP 10 min. JMarsh 1987 - 1996 F150 & Larger F-Series Trucks 27 06-23-2016 12:52 AM
1999 5.4 random misfire, chasing my tail Bootlegger's Deluxe Modular V8 (4.6L, 5.4L) 2 03-12-2016 09:51 PM
Help! Found more problems. Knock knock knock! E450 newbie 1999 - 2003 7.3L Power Stroke Diesel 16 12-19-2015 10:35 AM
Truck lost power then died. No codes gtclone 1999 - 2003 7.3L Power Stroke Diesel 7 05-04-2015 07:12 AM
Tags
2001, 46l, 68, engine, ford, knock, lines, low, noise, ping, pinging, rpm, spark, sputter, superduty, v10, vacuum, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
