Aerostar Suspension lift - Ford Truck Enthusiasts Forums
Aerostar Ford Aerostar
Old 12-11-2005, 03:19 PM
eschaerer eschaerer is offline
eschaerer is starting off with a positive reputation.
airialxxx10
Looking for info on how to raise suspension on late model AWD aerostar.
Gene
Old 12-11-2005, 03:55 PM
ken1mod ken1mod is offline
ken1mod is starting off with a positive reputation.
Air shoocks!!
Ken
Old 12-12-2005, 01:52 AM
Ed Ed is offline
Ed is gaining momentum as a positive member of FTE.
I use a 3 ton Craftsman Floor Jack on my Aerostar. I use the factory recomended lift points, and this floor jack lifts the suspension nicely. One pump after the ball engages the frame, and the Aerostar is lifted 2"-3" off the ground.
Old 12-12-2005, 06:49 AM
96_4wdr's Avatar
96_4wdr 96_4wdr is offline
96_4wdr is gaining momentum as a positive member of FTE.
Ed,
is it difficult and do you get stares driving your Aero around with it's Craftsman Lift Kit?
3" Lift Kit w 38" Mudders??
Old 12-12-2005, 11:40 AM
rebocardo rebocardo is offline
rebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud of
An AWD (or any -imo-) Aerostar is not amendable to lifting. Pretty much like any control arm type vehicle with front coil springs. You can get one or two inches, then slightly big tires, other then that it is a do-it-yourself-butcher-job.
You can add an extra spring leaf in the back or a small block lift.
I guess the real question is, why do you want to raise it?
Old 12-12-2005, 12:03 PM
copper_90680's Avatar
copper_90680 copper_90680 is offline
copper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant future
Quote:
To make crawling under the van easier for guys with big bellies like mine
Old 12-12-2005, 01:38 PM
Torsen Rick's Avatar
Torsen Rick Torsen Rick is offline
Torsen Rick is starting off with a positive reputation.
What, you mean not every one has a vehicle lift for doing work under the van?
Old 12-12-2005, 01:52 PM
93nighthawk's Avatar
93nighthawk 93nighthawk is offline
93nighthawk is starting off with a positive reputation.
Quote:
Ditto!
Old 12-12-2005, 03:39 PM
diskskratch diskskratch is offline
diskskratch is starting off with a positive reputation.
I managed to lift my AWD about 1-2". In the front, both springs were broken on the last coil, so I replaced them with front springs from a camaro, I forgot what year, but they gave it a firmer ride and about 1 1/2" after settling in. The back I put a decent set of blocks on the springs, and was thinking about the in-spring air bags, but haven't heard much good about them from a thread here a while ago. Air shocks aren't an option, as I have Rancho RS-5000's on all 4 corners, and they are too damned expensive to just take off and toss aside. With this little lift, I fit 225/70R/15 Yokohama Geolander AT/+II's on it with no rubbing whatsoever, they give it such a mean stance. So, in closing, it is possible to get a little lift, but not much.
Old 12-13-2005, 01:58 AM
Ed Ed is offline
Quote:
Originally Posted by 96_4wdr
Ed,
How did you know? Those metal wheels on the floor jack don't turn very fast either, and it's very noisy, even on just paved, asphalt! Ed
Old 12-13-2005, 04:26 AM
96_4wdr's Avatar
my ChineseMart 3 ton hi lift 19 incher will barely do 30 on the curves
Old 12-14-2005, 08:50 AM
What is wrong with air shocks? I have seen them on the front too.
Ken
Old 12-18-2005, 05:42 PM
xlt4wd90's Avatar
xlt4wd90 xlt4wd90 is offline
xlt4wd90 is gaining momentum as a positive member of FTE.
Quote:
Hi,
If you can find the specifics, I would really like to know. I would probably find an aftermarket version of the Camero springs that provide an inch drop to the stock, so it would leave the Aero in its stock height. But I am curious as to what model of Rancho 5000 shocks you got to fit the front?
Old 12-18-2005, 11:22 PM
I don't know, how I lift my Aero is jack up both sides of the front axle about 18 inches and then put a jackstand under each side near the arms. No room problems and I wear 3x shirts. The stomach is all muscle, honest ;-D
Old 12-19-2005, 02:16 AM
Ed Ed is offline
Putting aside my useless response, (Post #3) I was wondering too: Why do you want to raise the van? Considering the Aerostar, stock, already has a high center of gravity, what is your purpose? In case of a defensive manuaever in traffic, I would think you would want to make sure the Aerostar will handle, without any bad results. It's never going to corner like a new Mustang GT, but I think you see my point? Ed...
Steering wheel wrap RojoStar Aerostar 1 03-09-2016 09:06 AM
93 Aerostar overheating need replacement instructions LoneRanger3 Aerostar 3 07-05-2014 09:09 AM
Aerostar front suspension Franklin2 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 06-11-2014 04:09 PM
66 F100 Front Suspension 66rex 1961 - 1966 F-100 & Larger F-Series Trucks 27 01-13-2014 02:18 PM
aerostar suspension 66rex 1961 - 1966 F-100 & Larger F-Series Trucks 5 09-23-2011 03:55 PM
Tags
97, 976, aerostar, air, big, body, kit, kits, lift, lifted, rancho, rs, shocks, suspension, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
