Aerostar Suspension lift - Page 3 - Ford Truck Enthusiasts Forums
Aerostar Ford Aerostar
  #31
Old 07-25-2014, 04:08 PM
FrozenDrinkMan FrozenDrinkMan is offline
FrozenDrinkMan is starting off with a positive reputation.
What size tires?
If you get some pics, I would love to check it out.
flortex@yahoo.com
  #32
Old 07-25-2014, 05:04 PM
86CREW4ME 86CREW4ME is offline
86CREW4ME is starting off with a positive reputation.
I think it looks pretty cool...thanks
I'll take several pics tomorrow...working right now. I'll post several pics i took of the rear lift blocks before install too.
I believe if your looking for a rig as you described...this would probably suit your needs. i have taken it up a pretty steep rocky and grass incline prior to the lift. It does a really good job...Freaked my mother out a little...hahahaha
The tires are 205x75rx15 General Grabber AT2. They fit with no problems on a stock Aerostar (27 1/8" tall). If I had the lift prior to the tires, I could have went a little larger tire. The speedometer is electronic, and more accurate now than before.
The rims are American Racing Baja AR172 (15 x 7). A 215 series tire would have fit a little easier on the rim. The 205 is narrow and hard to set the bead.
The 215 would have been 27 3/4" tall, and i feared rubbing when i turned due to the additional 10 cm (appx 3/8").
  #33
Old 07-28-2014, 07:52 PM
Here are some pics...
I wish i had a little larger tire...definitely wider, but i will wait until i wear these out.
Rear Lift blocks
Rear lift block closeup
Rear lift block installed - suspension unloaded and shock connected.
No lift block installed - suspension unloaded and no shock connected
Completed lift
Completed lift
Rear view of lift installed - vehicle on ground
Rear block..snug fit
Front wheel opening
Rear wheel opening
  #34
Old 07-28-2014, 07:55 PM
Looks awesome!!
How does the 4.0 do? Plenty of power?
  #35
Old 07-28-2014, 07:56 PM
What did the overall lift come to?
  #36
I am planning to install a rear sway bar...
I will probably lower the rear brake line connection just to be safe. I am adding a stock used bracket, a short length of brake like and just reconnect. No modification to the hard line on the van.
Adding this lift DID affect the CAMBER of the front. It appears to be negative...but a little negative will make it handle better...i will get it checked when i have time, just to verify the numbers.
  #37
Old 07-28-2014, 08:02 PM
P.S. excuse my welds...I haven't welded in a while and should have practiced before i did these. I was in a hurry to get it done.
I welded the galvanized and got kind of nauseous for 24 hours...I took precautions, but not enough i guess...and milk doesn't help much after your already sick...f.y.i.
Zinc poisoning isn't very fun...lol
  #38
Old 07-28-2014, 08:07 PM
The 4.0 is adequate for power. I have towed stuff with this....
Typically utility trailers to the dump, etc....
I think i need to repalced my MAF again...The truck has a slow pulse feeling when i am going down the freewat
Rear wheelwell
The 4.0 is a much better engine than the 3.0. I have read there were a lot of problems with that engine.
  #39
Old 07-28-2014, 08:11 PM
I really like your van.
Thinking of upgrading to a 4.0 AWD.
Gonna need that kit!!!! lol
Steering wheel wrap RojoStar Aerostar 1 03-09-2016 10:06 AM
93 Aerostar overheating need replacement instructions LoneRanger3 Aerostar 3 07-05-2014 10:09 AM
Aerostar front suspension Franklin2 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 06-11-2014 05:09 PM
66 F100 Front Suspension 66rex 1961 - 1966 F-100 & Larger F-Series Trucks 27 01-13-2014 03:18 PM
aerostar suspension 66rex 1961 - 1966 F-100 & Larger F-Series Trucks 5 09-23-2011 04:55 PM
Tags
97, 976, aerostar, air, big, body, kit, kits, lift, lifted, rancho, rs, shocks, suspension, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
