fuel capacity for 90 f250 w/duel tanks - Ford Truck Enthusiasts Forums
Old 12-10-2005, 11:13 PM
f250newbie f250newbie is offline
f250newbie is starting off with a positive reputation.
wondering if anyone knew? searched and couldnt find anything. anyone know a link for the specs on a 90 f250 4x4,i cant find any info on this truck. thanks
Old 12-11-2005, 07:46 AM
jroehl jroehl is offline
jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.
F250 Reg Cab 2- and 4-wd: 22.0 gal front, 18.2 gal rear
F250 Super Cab 2- and 4-wd: 19.0 gal front, 18.2 gal rear
From the '90 F-series owner's manual.
Jason
Old 12-11-2005, 06:19 PM
Popa Tim Popa Tim is offline
Popa Tim is starting off with a positive reputation.
those look like longbed figures Jroehl
I think the front tank shortbed SC is 16 gal and the reg cab is 19. The rear tank is always 18.2 gal. Thats for the F150 which I don't think changed for the F250, did it?
Old 12-11-2005, 07:49 PM
i have a long bed ext. cab
Old 12-11-2005, 11:21 PM
1990 F250s didn't come with a shortbed. Reg cab long bed (133" wheelbase) or Supercab longbed (155" wheelbase) were the only options. The 16.5 gallon tank was only on the shortbed F150s in the front. F350 chassis-cabs and F-Superduties came with 19 gallon tanks front and back unless they had a diesel, then they had a 20 gallon front tank (except the DRW chassis cab F350 diesel, which had 20s front and back).
I've got the 1990 manual sitting right here...any more questions?
Jason
Old 12-12-2005, 01:19 AM
thanks jason, would you happen to know how i tell if i have the weaker mazda 5 spd tranny in my truck or not ??
Old 12-12-2005, 06:05 AM
What's the tranny code on your door sticker?
Or, what engine is in the truck, and what is the GVWR?
Jason
P.S. I just saw in another thread that you have the 351W--that means you definitely don't have the Mazda, you have the ZF. The Mazda doesn't fit the 351W bellhousing pattern (at least not from the factory).
Old 12-12-2005, 09:19 AM
whiteyfordzx5 whiteyfordzx5 is offline
whiteyfordzx5 is starting off with a positive reputation.
i'm sure Jason's correct, but just to be sure, crawl under and look for the ID tag on the tranny. if it's a ZF, it should have an ID plae on the driver side that says ZF somewhere on it.
Mike
Old 12-12-2005, 10:09 AM
thanks,ill crawl under there and check it out.
Old 12-12-2005, 10:35 AM
the_hetz's Avatar
the_hetz the_hetz is offline
the_hetz is starting off with a positive reputation.
If it's a ZF it will have a bunch of X's cast into the sides and stuff, the mazda has squares.
hetzel
Old 12-12-2005, 12:54 PM
coon1976 coon1976 is offline
coon1976 is starting off with a positive reputation.
I've got a 96 F-150 Reg. Cab Long box 4X4 and I candefinetly say that my front tank is bigger than the back
F250 Lug Nuts and STUDS.!!!!!!!!! bignewf 1987 - 1996 F150 & Larger F-Series Trucks 5 04-21-2016 12:31 PM
90 f250 4x4 7.3l Bruce Swedien 1999 - 2003 7.3L Power Stroke Diesel 5 11-10-2014 07:23 PM
Upgrade to earlier leaf spring hangers? Samsn4 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 01-03-2013 05:11 PM
Trying to find a 4.9L F250 4x4 kellyreed001 Ford Inline Six, 200, 250, 4.9L / 300 2 04-01-2012 06:54 PM
Rust free body parts clark5 1987 - 1996 F150 & Larger F-Series Trucks 2 05-06-2010 09:32 PM
Tags
250, 90, bed, capacity
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
