Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 12-09-2005, 12:22 PM
hollister hollister is offline
Garage is empty, add now
hollister is starting off with a positive reputation.
Thermostat problem on 2.3
Hey guys, I have a problem with my thermostat. I replaced it because the car runs very cool (about 130 degrees) on the freeway. I figured it didn't have one, but it did, and after it was replaed, it only ran marginally warmer than with the old one. Is there a bypass that I'm overlooking, or could the thermostat be in backwards? When I put it back together, the part of the thermostat with the spring on it was facing the engine block, which is the same way the other one was installed. Any help would be appreciated.
  #2 (permalink)
Old 12-09-2005, 08:11 PM
TigerDan's Avatar
TigerDan TigerDan is offline
1968 Ford F-250
TigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputation
Sounds like you got it in the right way. What year is the vehicle and is it EFI? What temp thermostat did you put in? EFI requires a 195º t-stat to function properly.
T-stats have been known to be bad right of the box. Might be that a piece of crud got in it and is holding it open as well.
BTW, I gave you your own thread on the subject. Better than tagging onto an old thread where your question might not get noticed.
__________________
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
Tags
23, duratec, ford, performance, problems, thermostat
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
