You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
You know where danbury schools is.I live right down the road. Right outside the gates of lakeside.Maybe we could get together on the weekend sometime.Would just like to make sure of a few things on my new engine.I have a 1979 F250 trailer special I am restoring.Just put a new crate engine in it from jasper this last summer.(400) Don't want anything bad to happen to it.
Yeah I know right where that is, I used to work at Camp Perry in the summers so I spent a lot of time in that area. I would be more than happy to stop by and help you out. I might not be available on the weekend till after the first of the year, but my evenings are open. Let me know.
putzhall3
I work 2nd shift during the week.I could take a day off,no big deal.I don't have a heated garage.Heck I can't even get my whole truck in there.Got lights though.Would be glad to have your help.Maybe next week if weather holds out.This week I have to put a gas tank in my wifes van.She ran over something in the road and put a hole in it.And she thinks she can drive my truck.HA HA
Hey Cooky did ya get everything figured out if not maybe I could be of some help. I am from Clyde and work in Sandusky if you have any questions I might be able to help.
NCL
I don't think I have everything quite right.Got choke stove hooked up but took electric choke off.Sometimes it seems to use to much gas.Do you think I need to hook up the electric choke back up?I think I need dist. moved and carb adjusted.I just don't know what I'm doing
Bob
I would hook the electric choke back up the timing for a 400 is 12btdc what kind of carb and intake are you running right now. And what knind of symptoms are you having with the engine. Sorry it took me so long to reply.
Got stock intake and stock 2 barrel.Sometimes this engine just dumps the gas.Not to often but alot when it does.
This engine will be 1 year old in july.
I don't have any vacumn hooked up just what I need.
This is a crate engine from Jaspers.
Runs pretty good just think I need to get all the bugs
Myself I'm not much of a mechanic.
Would like any help I could get.
Thanks for getting back with me.
What do you mean by dumps the gas, do you mean using gas or actual spillage. You can get rebuild kits for those carbs for pretty cheap but swapping in a dual plane manifold and a aftermarket carb really makes them come alive. I run a edelbrock 600 cfm 4bbl w/elec. choke and edelbrock performer manifold on my 400 and also have no smog stuff hooked up it has all been eliminated. I get about 9-10 mpg with 4.10 gears and 36" tires. But am thinking about swapping to a howell efi kit. Maybe think about rebuilding your carb and make sure you dont have any vacuum leaks cause those can give you trouble too.
I mean uses gas only hasdone it twice in the last 4 months.I.m getting just under 12 mpg highway.Maybe I ought to just leave it alone.It's running good just thought their might be a reason it dumps gas like that.Could it be the choke sticking every once in awhile?
