07 Super Duty - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
07 Super Duty
Old 12-08-2005, 05:04 PM
QAman QAman is offline
QAman is starting off with a positive reputation.
Question 07 Super Duty
Has anyone heard the latest on the 07 yet? Pictures or motor specs? All I've heard is twin turbo 6.4, maybe a Cat instead of PSD.
Old 12-08-2005, 05:34 PM
JD717 JD717 is offline
JD717 is starting off with a positive reputation.
From what I've heard, CAT is an unlikely motor for the SD trucks, though it WOULD be cool.
Old 12-08-2005, 06:06 PM
kw5413's Avatar
kw5413 kw5413 is offline
kw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputation
Old 12-08-2005, 06:18 PM
F2FIFTY's Avatar
F2FIFTY F2FIFTY is offline
F2FIFTY is starting off with a positive reputation.
Should be something interesting, but I do not see a major face lift. Most likely a different power plant.
"Delayed due to Ford's financial constraints, the heavy-duty workhorse truck range is ultimately destined to receive major changes for 2007. This Crew Cab longbed 1-ton version sports a single rear wheel, and looks to offer a slightly larger cab area. Word around the office says this vehicle is being tested with a new, smaller V-6 4.5-liter turbodiesel sourced from International, promising improved fuel economy."
"The heavy-duty workhorse truck range will be redesigned. The 6.0L diesel engine to be replaced by a more powerful 6.4L diesel."
http://www.u-ka.cn/en/00/80369.html
Old 12-08-2005, 07:01 PM
kw5413's Avatar
Again boys and girls, there is an entire forum here dedicated to the '07 / 6.4.
Old 12-08-2005, 07:09 PM
BigF350 BigF350 is offline
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
And therefore, this thread shall be moved there
Old 12-10-2005, 01:45 AM
Louisville Joe Louisville Joe is offline
Louisville Joe is gaining momentum as a positive member of FTE.Louisville Joe is gaining momentum as a positive member of FTE.
They are being tested here in the Los Angeles area. The grille and bumpers are covered, but the rest of the exterior looks about the same as it does now. Under the hood is supposed to be this new International 6.4L, which is rumored to have a twin turbo setup (though it looks like only the compressor side is twinned, it only has one exhaust turbine) and common-rail fuel injection like the Duramax and late model Cummins. The interior is new, and the chassis is new as well. Supposedly the frame is now completely boxed, like the new Ram HD's.
Old 12-11-2005, 12:42 PM
Ry_Trapp0 Ry_Trapp0 is offline
Ry_Trapp0 is starting off with a positive reputation.
thats gonna be one hell of a stiff frame i suspect.
Old 12-11-2005, 12:47 PM
MIKE1646's Avatar
MIKE1646 MIKE1646 is offline
MIKE1646 is starting off with a positive reputation.
I just want to see the engine
Old 12-11-2005, 06:59 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie PowerstrokeJunkie is offline
PowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to behold
Quote:
http://www.ford-trucks.com/forums/sh...d.php?t=435290
Old 12-13-2005, 08:43 PM
MIKE1646's Avatar
Thanks for that link Strokin_it 7.3
Old 01-11-2006, 01:38 AM
bocomojoe bocomojoe is offline
bocomojoe is starting off with a positive reputation.
Is it possible to see 2 diesel motors offered? In addition to the 6.4 I would like to see the 4.5 (or 4.8) make available as an option. Also a 6 speed auto tranny. Along with common rail injection and TT if there were some way to get rid of the EGR I think we would be in business.
Old 01-11-2006, 09:32 AM
PSD6litre40's Avatar
PSD6litre40 PSD6litre40 is offline
PSD6litre40 is starting off with a positive reputation.
Rumor has it the Torqshift will be a 6 Speed auto in 2007. Also, why a 4.5 in a Super Duty? Save it for the F-150's!
Old 01-11-2006, 10:33 PM
Crash687's Avatar
Crash687 Crash687 is offline
Crash687 is gaining momentum as a positive member of FTE.
Quote:
Doesn't the Torqshift have 6 speeds in it already but only 5 are utilized depending on conditions/demand? (I could be wrong)
Old 01-12-2006, 01:39 AM
NickFordMan's Avatar
NickFordMan NickFordMan is offline
NickFordMan is gaining momentum as a positive member of FTE.
Well, they'll be adding a gear to it either way it sounds.
Difference between '06 & '07 5.4 heads Powerws 2004 - 2008 F150 3 10-22-2007 01:11 AM
F150 Bigmonts Tennessee Chapter 3 11-12-2006 10:45 PM
Flowmasters? bassproguy07 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 16 10-30-2006 09:51 PM
Twin Turbo QPS 1999 to 2016 Super Duty 3 08-11-2006 07:17 AM
V-10 not in the specs for 07 rgdowntheroad Modular V10 (6.8l) 18 05-01-2006 10:43 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
