What does this do??
What does this do??
I tried looking all around the web but never found the first pic that has this. On my motorcraft 2100 carb, there's a what looks like a small vacuum diaphram with a nipple for a hose to connect to, that sits right on the front of the Carb, outside the bowl, to the right of the filter and above the power valve.
What does this do and what hose connects to it?? Maybe a hose from the charcoal cannister?
It sounds like an old carb with an external power valve. Is there a standard Ford part number on the carb, or a tag on one of the float bowl screws? The number would start out something like C4TE, C4AE, etc. The first two digits are the year, C=60's, the second digit is the specific year, so C4 is 64.
A Temperature Compensated valve body will augment the accelerator pump system. The entire system is called the temperature compensated accelerated pump.
Yes, that's it. Would it be okay if it's not hooked up? Mine don't have anything going to it.
BTW, it has E3TE AVA on the tag and it's on an '83 F100.
Originally Posted by subford
Yes, but your engine would be a little slow to respond when cold. What it does is restrict the amount of fuel that your accelerator pump can deliver when your engine is warm. When your engine warms up you get full vacuum on it and the fuel will be restricted (bypassed back to the fuel bowl) from the accelerator pump to your engine.
Let me make sure I got this right. It restricts the flow when it's warm and it has full vacuum. So when it's cold, it has little or no vacuum and not restricted meaning more fuel through the accelorator pump? Then why would it be slower to respond with more fuel when it's cold ? Now my head hurts!! :-)
Frmnsal
06-13-2016 08:15 AM
RIchard Chapman
11-23-2013 10:28 PM
FordTrucksKickGM
12-08-2009 04:17 AM
