00 - Shock Absorbers for 4WD w/LLS
Hello all,
It's time to replace my shocks, and I have the LLS system with 4WD. I drive mostly just plain street/highway, very little four wheelin'.
Looking through the forum, I'm pretty sure that the Bilsteins are my choice for the rear.
However, I'm having a devil of a time finding shocks for the front. I've discovered the Monroe #40004, but they are $116 EACH!
Local "Tire/Brake/Shock" houses have quoted between $500 and $540 (installed), but that seems excessive to me.
I don't mind spending good money on good parts, but I've read a lot of negative comments on the Monroes.
I would appreciate your thoughts or suggestions on manufacturers, part number would be extremely helpful, or links.
My deepest thanks to you all.
Roger
Roger
Originally Posted by Quietman64
Hello all,
Roger
Roger
http://www.fordpartsonline.com/
If you have mechanical ability and tools and are up to it, replacement is very simple. You will need basic tools to do this, only difference will be the front shocks and there are posts on here on how to do that.
Good luck
Thanks to all for your thoughtful responses.
One last question, -way- back in the archives, someone had mentioned that the front shocks do not need to be replaced UNLESS they are damaged.
Any further thought or opinions? I always appreciate any ideas from the folks with superior experience and judgement.
4wd and LLS your pretty much limited to choice of shocks. Most with the 4wd system will replace the rear with a quality shock like Bilstein (like you have noted) and replace the front with OEM. You can get OEM for less than the Monroe you noted. Look at some of the online part houses like;
Ford Parts Online - Genuine Wholesale Ford Parts
Good luck
Good luck
STEP 1: Learn how to do a search
I just did mine along with ball joints I got the monroes from carstuff.com for $89 each and if you ask they give you free shipping I called and talked to someone directly. BTW the ride was much improved!! Check your ball joints to they are prone to fail at 100000 mi. give or take. If there in the area already ya might as well do those to no what I mean. good luck
On these trucks with LLS Moroe is the only choice for the front. There is a little ring that goes around where he air line connects with the shock. Push in on that ring it will move in around a 1/16 to an 1/8. Push in on the air line with a little presure, then pul the air line out. Keep pushing in on the ring part until the air line comes out. Clean the end of the air line before putting it in the new shock. You may also have to trim the air line back a little to get a clean end on the air line. It now removes like a regular shock. You will need to compress both the old to remove it and the new to get it into position, this is probly the hardest part of the whole thing. The rears are just standard shocks. The hardest part on the rears is working around the gas tank. Not real hard just takes time.
I used Bilstiens on the rears and I am very happy with them.
Monroe 40004
Well, yes, I know you must bleed the air line first, I also saw that you need to find the "T" connection closest to the left front shock and "press" it to bleed the air. Do you have anything to add to make this more clear? Ford has made it next to impossible to find out exactly how to do this work so they can support their mechanics at the dealers, so I appreciate any directions any of you have. Thanks! (BTW I did give up on that crazy drivers side rear shock as the top bolt is impossible to access without an air wrench. The gas tank is in the way. I paid $60 for a mechanic to do that one shock replacement for me, labor only!)
