4 wheel ABS vs. RABS on '97 Ranger 2WD
I was wondering how to tell if you have 4 wheel ABS versus just Rear wheel. ABS. In one of the threads I found it mentions that the RABS unit is on the driver side frame rail, where as the 4-wheel ABS in the engine compartment.
Can someone confirm this and fill me in on as to what the units look like and where exactly on the frame rail or engine compartment they are located?
I need to get new front rotors and would like to make sure I get the correct ones...ABS or non-ABS rotors. I assume there are gear teeth on the rotors for the ABS sensor if the fronts are ABS rotors? yes?
1997 Ranger XLT 2WD extra cab
Thanks in advance!
Thanks in advance!
the rotors certainly look similar, but Brembo lists 2 different part #s depending on 4 wheel vs. rabs.
http://www.buybrakes.com/brembo/am-a...%20Trucks.html
i'll check mine for sensor teeth.
thanks!
thanks!
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
12-18-2014 07:33 AM
madcarpenter
02-28-2012 05:51 PM
84-250
02-22-2007 03:10 PM
