99 F-250 stuck in 4 wheel drive - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-07-2005, 10:27 AM
bluemoon7 bluemoon7 is offline
bluemoon7 is starting off with a positive reputation.
Hi,
I am new here but I am really impressed with what i see.... there is a lot of knowledge here. My 99 Ford (7.3 Diesel) will not come out of four wheel drive. I have ESOF with maual hubs. Originally when I bought this truck it would not go into 4X4 low, and now I can't get it out of 4X4. (transfer case not the hubs) When I shut off the ignition I can hear a click like the solenoid is disengaging, but am not positive that's what it is. Is there any way to figure out if it is the switch or the solenoid or something else? I checked the wires on the back of the switch and on one of the wires I do get a voltage change when moving the switch. Any help would be greatly appreciated !!
Old 12-07-2005, 10:31 AM
sdpj sdpj is offline
sdpj is starting off with a positive reputation.
try driving in reverse about 10 to 20 ft with your switch in 2 wheel drive. that's always a little trick to gettin em out of 4 wheel drive. let us know what happens.
Old 12-07-2005, 10:43 AM
Big Orn's Avatar
Big Orn Big Orn is offline
Big Orn has a very good reputation on FTE.Big Orn has a very good reputation on FTE.Big Orn has a very good reputation on FTE.
Welcome to FTE
Is the tcase stuck in High or Low?
Old 12-07-2005, 12:13 PM
Thanks for the replys !
Sorry about the confusing post... The transfercase is stuck in 4 high. I have left the hubs locked in the past week or so and just used the switch... now it just won't come out of 4 high. The fact that previous to this is the truck would not go into 4 low is not really related to this I don't think. I will try backing up 20 ft or so and see if this does the trick.. I will let you know. Thanks again.
Old 12-07-2005, 12:22 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
One thing, the servo will stop trying after a while...
So, put the switch back in 4x4, wait a minute, and then try again.
"Bounce" the drivetrain, while trying to get it out of 4x4, as in, turn the **** to 4x2, and quickly go from reverse to drive, and back again, back and forth.
Sounds like you could have a bad servo (what a coincidence).
Is it really stuck in 4x4, or is the light just stuck on?
Old 12-07-2005, 01:54 PM
Big Orn's Avatar
Yea - chock the tires, unlock the hubs and see if the front driveline turns. Could be the light...
Old 12-26-2005, 06:56 PM
Sorry for the long delay, I have just been extremely busy and haven't had any time to look at this thing... thank you for all the advice. I have looked into this and the transvercase is locked in 4 high. It is not the light. I tried everything you guys recomended and it will still not come out of 4x4. I am assuming it is something on the transfercase??? I looked at the transfercase and saw two electrical plug ins. One looks like a solenoid (servo?), and the other is round and flat. Is there a way of checking this out? I am not very familiar with transfercases, but with some explanation I am sure I can figure it out. Thanks again for the help.
2005 F350 4x4 questions? deputydog03 1999 to 2016 Super Duty 15 12-10-2015 08:40 PM
Yep, another IWE question...(I swear I did all the prerequisites!) eshallbetter 2004 - 2008 F150 12 01-16-2014 02:51 PM
NEED HELP: 2003 F350 7.3L 4X4 not working shield1978 1999 - 2003 7.3L Power Stroke Diesel 8 10-12-2013 09:00 AM
99 ranger 4x4 wiring diagram? jyarosz Ranger & B-Series 5 09-16-2012 11:03 AM
4x4 front hubs only works intermittent cowboylelle 1999 to 2016 Super Duty 22 10-12-2010 09:05 AM
Tags
150, 1999, 2001, 2002, 250, 4wheel, 73, 99, dr, drive, f250, ford, low, stuck, wheel, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
