Help
Alaska Chapter Link
Hey TXBDBY, If you haven't already received it from mlb... here's the link I think you are looking for....http://akftechapter.angelcities.com If the above link is blocked then try this:
http://akftechapter(dot)anglecities(dot)com
(fte blocks some addresses so enter in the address but where the (dot) is actually put in a .
Hope this helps, Chris
Ah that. Kinda thought you were looking for that. Trying to remember but I thing I downloaded the picture from the Internet. I did a search for either "State Maps" or "Alaska Maps". Came up with different Ideas. I then added the text using an imaging program. I have Unlead at home but most imaging will allow you to add text over a picture. Saved it then reopened it, shrunk it down to a smaller size for uploading to FTE and wala done. I'll take a look and see what I have for images.
