what is this light?
Old 12-06-2005, 04:31 PM
johnstechhelp's Avatar
johnstechhelp
johnstechhelp is offline
Question what is this light?
on the basic guage cluster with the Tach and the Mini Message Center there is a light between the Fuel Guage and the Tachometer? Does anyone know what this is?
Old 12-06-2005, 09:03 PM
fordfanatic05's Avatar
fordfanatic05
fordfanatic05 is offline
what does the light look like?
Old 12-06-2005, 09:12 PM
xtrm1stang's Avatar
xtrm1stang
xtrm1stang is offline
Owners manual should tell you under instrumentation, at the begining of the book.
Old 12-06-2005, 10:38 PM
johnstechhelp
the light is not in the manual, nor does it light up when I turn the ignition on. it looks like a car skidding off the road
Old 12-06-2005, 10:40 PM
johnstechhelp
it is an 05 screw
Old 12-06-2005, 11:11 PM
Monsta's Avatar
Monsta
Monsta is offline
Sit. Stay.
Sounds like a Traction Control light.
Old 12-07-2005, 12:57 PM
johnstechhelp
thats what I was thinking...and i figured that since my truck doesn't have traction control, thats why it doesn't work
Old 12-07-2005, 02:33 PM
KevinM's Avatar
KevinM
KevinM is offline
The 2006 XLT and Lariat has traction assist as an option for $195 this is not to be confused with limited slip! Go to the Ford site and you will see the options.
Old 12-07-2005, 05:45 PM
fordfanatic05
That's definetly what it is Traction assist of traction contol. It will light up briefly when you start up the make sure the bulb works. It will also light up if the truck is experiencing slipery conditions on the road like rain or snow. When it comes on it also means the traction control system is active and trying the help you from spinning the wheels and keeping the truck in a s8 line. Its a great feature to have!!!
Old 12-07-2005, 06:05 PM
johnstechhelp
did does not light up at all
Old 12-07-2005, 06:07 PM
johnstechhelp
no traction assist on my truck
Old 12-07-2005, 06:15 PM
fordfanatic05
If it did not light up how did you see it then??
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
then it will remain unused.
Old 12-07-2005, 08:03 PM
johnstechhelp
i was cleaning the dash and caught it at an angle
Old 12-07-2005, 08:53 PM
fordfanatic05
Oh ok, i Do that sometimes when looking at dash on the escape the sun has to be in the right position but i can see the spot for lights that dont light up on start-up. (advance-trac light,low anti-freeze and low washer fluid light) but it makes me wonder is the bulb just out? I would like to have those lights in use also.. o well
Good luck
B_D
New Member Introductions
09-22-2008 03:50 PM
cyrexpl
1999 to 2016 Super Duty
08-22-2007 06:07 PM
BMOHIO
02-01-2007 12:02 PM
DocJDement
2004 - 2008 F150
03-04-2006 10:06 PM
srwells
10-04-2005 07:07 AM
Quick Reply: what is this light?
