Relays click then nothing when bat. connected
Hi, I have a 1997 F250 Powerstroke truck. All was fine until I removed the right battery. It was out for about four days.I did nothing with the truck during this time. When I put the battery back in three or four relays (left side of dash on top and under the hood in front of the brake cylinder)will click away for roughly ten seconds then stop (This is with the key off.). The clicking always starts again when I try to start it. Turning the key to the on position lights what look like the normal dash lights but nothing happens when I turn it to the crank position. I did find that the battery that was left connected in the truck was down to about five volts. After charging there was no difference. When I connect the first battery (when both are unhooked)it arcs like the lights or something are on. Everything is off. Sorry so long winded. Any help would be appreciated.
Thanks, Ed
Thanks, Ed
Thanks, Ed
Thanks, Ed
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
This is going to sound stupid. I just bought the truck a little over a week ago and was never told it had an anti theft system installed in it. Apparently when the battery is reconnected it sets it off. There were two relays that were a part of the theft system. I could hear them clicking up by the light switch. When I took the dash apart I saw a box that had Viper on it. It all started to come together then. I disconnected it and the truck runs fine now. Thanks for the help.
