Removing door and tailgate emblems - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-06-2005, 03:33 PM
Miescha's Avatar
Miescha Miescha is offline
Miescha is starting off with a positive reputation.
How are the door, tailgate, and quarter panel emblems attached? It looks like just double-sided tape (heavy duty) and some pins (just for alignment).
Mine are pretty worn and flaking off, so I'd like to replace them with the newer '05 emblems (pretty cheap from the dealer).
Can I just use a heat gun on low setting and some fishing line to get them loose without damaging the paint? Is there a better method?
Old 12-06-2005, 04:14 PM
schmidt64 schmidt64 is offline
schmidt64 is starting off with a positive reputation.
Been planning on doing this too, any ideas?
Old 12-06-2005, 04:26 PM
BerkshireCoverit's Avatar
BerkshireCoverit BerkshireCoverit is offline
BerkshireCoverit is starting off with a positive reputation.
ok i'll helpya out this one time, i think the fastest way would be with a grinder 40 grit wheel , that should take it off fast and without much efford in just a few seconds be careful not to scuff the clear coat , that could get costly glad to help gl
Old 12-06-2005, 04:36 PM
Miescha's Avatar
Quote:
Gee, thanks for the help. Maybe it would be even faster to remove the emblems if I just back into my garage and scrap the panel along the house!
I hear this is a common occurrence anyway
Old 12-06-2005, 04:40 PM
Wise a-- say good night gracie nite nite
Old 12-06-2005, 04:59 PM
Miescha's Avatar
I'm glad we have such a humorous crowd here at FTE!
Old 12-06-2005, 05:02 PM
F3504ME F3504ME is offline
F3504ME is starting off with a positive reputation.
Thats the way my ex wife used to do it...
Old 12-06-2005, 05:06 PM
guzzle92's Avatar
guzzle92 guzzle92 is offline
guzzle92 is a name known to allguzzle92 is a name known to allguzzle92 is a name known to allguzzle92 is a name known to allguzzle92 is a name known to allguzzle92 is a name known to all
I removed a stealership emblem that was fastened in the same manner with double sided tape.
I used a narrow metal spackle knife to force between the emblem and truck, kinda slicing through the tape. With some light pressure, pulling away from the truck, the emblem finally gave way and I could pull it the rest of the way off by hand. What was left was alot of the double sided tape goo. I saturated it with Goo-Gone and with a nylon spackle knife and a soft cloth, was able to remove the remainder.
My Powerstroke emblem was starting to fall off the front left quarter panel and I simply removed it by hand but still had some of the tape remaining that I delt with the same way. To re-install it, I had some 3M automotive tape made for installing door protection, fender flares, etc. to automotive finishes. Looks like the same stuff Ford uses but in 3/4" rolls. I have seen this tape in K-Mart craft departments but it's not labeled 3M. Gray double sided tape with a red plastic protector covering one side of the tape. REAL STICKY stuff.
Old 12-06-2005, 06:19 PM
Customz's Avatar
Customz Customz is offline
Customz has a good reputation on FTE.Customz has a good reputation on FTE.Customz has a good reputation on FTE.
the f250/350 badges have two centering pins
Old 12-06-2005, 06:26 PM
alchymist's Avatar
alchymist alchymist is offline
"Mifflin Clay"
alchymist is a splendid one to beholdalchymist is a splendid one to beholdalchymist is a splendid one to beholdalchymist is a splendid one to beholdalchymist is a splendid one to beholdalchymist is a splendid one to beholdalchymist is a splendid one to behold
Question
Quote:
But are the tailgate and fender alignment pin dimensions the same?
Old 12-06-2005, 10:31 PM
sriddle's Avatar
sriddle sriddle is offline
sriddle is starting off with a positive reputation.
I pulled the powerstroke ones off by putting a large exacto blade under the emblem to protect the paint and then used that to pry against eventually popping it off. You can actually order personalized billet badges to replace them. I havnt decided what to put on mine yet.
Old 12-06-2005, 10:53 PM
Miescha's Avatar
Badges? We don't need no stinking badges.
Where do you order the personalized badges?
Old 12-06-2005, 10:57 PM
sriddle's Avatar
Old 12-07-2005, 12:32 AM
skipperw skipperw is offline
skipperw is starting off with a positive reputation.
He does great work. Check my gallery. His directions for taking off badges is fishing line. Worked for me. Then Goo Gone.
Old 12-07-2005, 09:39 AM
Customz's Avatar
Come to think of it, the tailgate oval is recessed. I couldn't say if it has centering pins or their dimensions. I know because I want to remove all logos and heard the 250/350 is problematic and then noticed the tailgate is recessed.
I may still remove the powerstroke badges if I have time. I have always used a nylon putty knife on numerous chevies. The newer the adhesive the easier they are to remove.
Reproduced hood emblems for F250 + teardropty 1948 - 1956 F1, F100 & Larger F-Series Trucks 23 01-05-2016 08:16 AM
Custom Tailgate Emblem brmccolley Aftermarket Products 2 10-07-2015 08:37 PM
Securing Emblems ZSK 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 10-18-2013 07:45 PM
2011 King Ranch Tailgate Emblem Measurements mackda600 1999 to 2016 Super Duty 1 04-16-2011 05:57 PM
blue FORD emblem manstruck Aftermarket Products 15 06-19-2003 07:53 AM
Tags
2006, badge, door, emblem, emblems, f150, f350, f81z2c150aa, ford, removal, remove, removing, replace, tailgate, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
