Fuel tank replacement
You could try to get a gas tank from a Bronco. They had the big 35 gallon tanks if I remember right. You should get new fuel filler hoses but I would think you could still use the sending unit from the donor tank. Just look in the paper for someone parting out an 80-86 Bronco and make 'em a deal.
I've thought about used, or junkyards....but, I figure a bad tank can clog a filter at the most inconvenient time (rust), so I'm going with new....I plan on keeping this truck forever.
Which supplier do y'all feel comfortable with...I'm starting to consider looking around Houston for a local supplier. I'm getting hooked on this on-line ordering.
Well, LMC Truck has a 38 gallon replacement tank to replace the stock 19 gallon unit.
It includes the lock ring, o-ring, drop bolts, spacers, and an adapter kit to extend the old sending unit so it will work on the new tank. They have it listed for $300.
I've considered the 38gal.....but, I'd have to move the tire support and I don't know if I could run dual exhaust at some point. Seems like an easier fix however.....only one install, only one sending unit, etc. Same fuel supply as 2 19's, but then, I'd have a switch I can't use by the heater-A/C control panel.
I'm making this difficult......I may go with two 19gal poly's and not think about rust anymore. I'd never have to worry about tanks again.
Just for grins, I've thought about the 38gal AND a 19 side mount.....
Originally Posted by stan v
Know it all son says I should change out the sending units as well.....says the old ones may not work after removing from 20 year old tanks.
Most ALL sending units tend to go BAD after 20 years or so. I know there are friggin outrageously EXPENSIVE, but considering the alternative of keeping an eye on the Odometer ALL THE TIME....
cbr600f31997
04-14-2014 04:41 PM
murphysdad
01-06-2012 03:29 PM
thegreytruck
04-30-2007 12:06 PM
