Making big HP with the 2.3L. It can be done!
Old 02-26-2006, 03:21 PM
2.3L_ranger_fan's Avatar
2.3L_ranger_fan
2.3L_ranger_fan is offline
cant that mess something up cutting wires and extendin them?
  #47
Old 02-26-2006, 06:15 PM
powerdog's Avatar
powerdog
powerdog is offline
It depends how good of work you do. Thats whu I quoted
It is important that you use the best equipment and wiring.
If you use the best conectors with the right guage of wire do a very good job you won't have a prob.
  #48
Old 03-01-2006, 09:11 PM
2.3L_ranger_fan
okay i got everything installed and ready to go. but i noticed that the IAT sensor. (the sensor right before the throttle body) didnt have a place to hook up. do i need to drill a hole in the boost pipe to put it in or what?
  #49
Old 03-01-2006, 09:34 PM
powerdog's Avatar
powerdog
powerdog is offline
Yes you do. It must be right before the intake on the presure side of the turbo.
So what are the mods? I would not minde having a rundown of your setup. Inj size, MAF size ect...
  #50
Old 03-02-2006, 02:43 PM
2.3L_ranger_fan
its a 97 ranger.
the turbo is a garrett t3 ball bearing 61mm turbo, runnin bout 18 psi
the intercooler is a megan racing universal intercooler
im using 39lb injectors and a 90mm maf sensor.
the clutch im using is a hays super truck.
i also put on an ACCEL ignition control system and 2 new accel super EDIS coil packs.
  #51
Old 03-02-2006, 04:06 PM
powerdog's Avatar
powerdog
powerdog is offline
Originally Posted by 2.3L_ranger_fan
its a 97 ranger.
Sounds good!! I see you know what you are doing.
  #52
Old 03-02-2006, 04:46 PM
2.3L_ranger_fan
yea thnx to all ur help thats bout the only way i got it done. i had no idea u could use could half that stuff on a ranger.
  #53
Old 03-09-2006, 08:47 AM
nate_is_the_1's Avatar
nate_is_the_1
nate_is_the_1 is offline
on that sct thing. can u tune ur stock computer to run those big injectors and MAF sensor. or do u have to buy a new street computer
  #54
Old 03-09-2006, 08:36 PM
powerdog's Avatar
powerdog
powerdog is offline
The stock computer is used. It just burns a new tune in it.
  #55
Old 03-12-2006, 04:01 PM
2.3L_ranger_fan
sup powerdog? trucks runnin great lovin the HP. but i was wonderin do u think my engine can handle a 50 or 100 shot of nos?
  #56
Old 03-12-2006, 06:35 PM
powerdog's Avatar
powerdog
powerdog is offline
If you are running the turbo forged pistons yes. Nos is good keeps detonation down cools intake temp. If you got the turbo pistons you are safe any ware under 450HP
are you a member over at RPS?
  #57
Old 03-13-2006, 08:35 AM
2.3L_ranger_fan
nope. not yet
  #58
Old 03-29-2006, 09:13 PM
nate_is_the_1
if you put in new performance cam, lifters, and rockers can the engine handle more than 450 horsepower?
  #59
Old 04-08-2006, 09:47 PM
2.3L_ranger_fan
it might be able to hold another 25-50 hp..but im not exactly 100% sure.
  #60
Old 04-30-2006, 08:30 PM
todder53's Avatar
todder53
todder53 is offline
powerdog how is that spec stage 4 clutch for a daily driver? Would stage 3 or stage 3+ work with that same kind of power. Just asking because spec states that the stage 4 isn't for daily driving due to harsh engagement and stage 3 and 3+ is better for daily driving.
Quick Reply: Making big HP with the 2.3L. It can be done!
