Making big HP with the 2.3L. It can be done!
#32
Originally Posted by 12345678910
where did you get the turbo and how much??
Here is a list of turbos that work great.
IHI from 87-88 thunderbird turbo 2.3 stock turbo.
T3 from SVO mustang.
The IHI will spool very quick. The t3 is pretty good to but these turbos will not make the power like the turbos listed below.
Below some good turbos that have a little more lag but make a lot more HP.
Holset HX35
Holset HY35
Holset H1C These holset turbos will do very well into the 400HP bracket. I would recomend a performance header such as a stinger header helps a larger turbo spoll quicker.
TTere is a guy in T with an SVO mustang 2.3L turbo he runs 9sec in the 1/4mi makes 700 RWHP I heard he is running a turbo off of a cat diesel motor.
There is also a turbo on ebay sold from SSautocrome it is a t70 supper spool it spools fast and is good for 500hp.
#33
#34
#35
Just as long as they are high impedance injectors. Focus injectors will work to. You will need to tune injectors and maf on a dyno. Finde a local dyno performance shop that is a dealer with sct. You could use 36-60lb injectors just so they are high imp.
if you need a stg 3 or 4 clutch check here http://www.nolimitmotorsport.com/ I used a spec clutch.
#36
#42
Originally Posted by 2.3L_ranger_fan
so is a stinger head the same header that comes with that t3 turbo kit from ebay you was talking about.
#45
If you look up on the fire wall right at the back of the motor you can see the one coil pack. The other one is right behind the boost pipe on the drivers side of the motor. you will need to mod your wiring harness by extending some of the wires. It is important that you use the best equipment and wiring.
Or you could see pic at my sight www.RangersRevenge.com
