Making big HP with the 2.3L. It can be done! - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 02-26-2006, 03:21 PM
2.3L_ranger_fan 2.3L_ranger_fan is offline
2.3L_ranger_fan is starting off with a positive reputation.
cant that mess something up cutting wires and extendin them?
  #47
Old 02-26-2006, 06:15 PM
powerdog powerdog is offline
powerdog is starting off with a positive reputation.
It depends how good of work you do. Thats whu I quoted
Quote:
It is important that you use the best equipment and wiring.
If you use the best conectors with the right guage of wire do a very good job you won't have a prob.
  #48
Old 03-01-2006, 09:11 PM
okay i got everything installed and ready to go. but i noticed that the IAT sensor. (the sensor right before the throttle body) didnt have a place to hook up. do i need to drill a hole in the boost pipe to put it in or what?
  #49
Old 03-01-2006, 09:34 PM
Yes you do. It must be right before the intake on the presure side of the turbo.
So what are the mods? I would not minde having a rundown of your setup. Inj size, MAF size ect...
  #50
Old 03-02-2006, 02:43 PM
its a 97 ranger.
the turbo is a garrett t3 ball bearing 61mm turbo, runnin bout 18 psi
the intercooler is a megan racing universal intercooler
im using 39lb injectors and a 90mm maf sensor.
the clutch im using is a hays super truck.
i also put on an ACCEL ignition control system and 2 new accel super EDIS coil packs.
  #51
Old 03-02-2006, 04:06 PM
Quote:
Originally Posted by 2.3L_ranger_fan
its a 97 ranger.
Sounds good!! I see you know what you are doing.
  #52
Old 03-02-2006, 04:46 PM
yea thnx to all ur help thats bout the only way i got it done. i had no idea u could use could half that stuff on a ranger.
  #53
Old 03-09-2006, 08:47 AM
nate_is_the_1 nate_is_the_1 is offline
nate_is_the_1 is starting off with a positive reputation.
on that sct thing. can u tune ur stock computer to run those big injectors and MAF sensor. or do u have to buy a new street computer
  #54
Old 03-09-2006, 08:36 PM
The stock computer is used. It just burns a new tune in it.
  #55
Old 03-12-2006, 04:01 PM
sup powerdog? trucks runnin great lovin the HP. but i was wonderin do u think my engine can handle a 50 or 100 shot of nos?
  #56
Old 03-12-2006, 06:35 PM
If you are running the turbo forged pistons yes. Nos is good keeps detonation down cools intake temp. If you got the turbo pistons you are safe any ware under 450HP
are you a member over at RPS?
  #57
Old 03-13-2006, 08:35 AM
nope. not yet
  #58
Old 03-29-2006, 09:13 PM
if you put in new performance cam, lifters, and rockers can the engine handle more than 450 horsepower?
  #59
Old 04-08-2006, 09:47 PM
it might be able to hold another 25-50 hp..but im not exactly 100% sure.
  #60
Old 04-30-2006, 08:30 PM
todder53's Avatar
todder53 todder53 is offline
todder53 is starting off with a positive reputation.
powerdog how is that spec stage 4 clutch for a daily driver? Would stage 3 or stage 3+ work with that same kind of power. Just asking because spec states that the stage 4 isn't for daily driving due to harsh engagement and stage 3 and 3+ is better for daily driving.
boost Brandon Crannell 4 Cylinder Engines 1 12-11-2016 07:24 PM
2001 7.3 Powerstroke - Custom Build 400-450HP 7.3 PStroke 1999 - 2003 7.3L Power Stroke Diesel 46 08-09-2016 07:48 AM
WW2, Turbo Rebuild, and the lil Turbo Bolt that Couldn't......(engine porn) KJNDIVER 1999 - 2003 7.3L Power Stroke Diesel 29 07-30-2014 07:23 PM
Pull vids 9/8 Smithton PA 2nd Place mech2161 1999 - 2003 7.3L Power Stroke Diesel 26 09-11-2007 10:07 AM
turbo charge? wethugin87 4 Cylinder Engines 1 02-23-2006 10:16 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1999, 2003, 23, 23l, 25l, 97, engine, ford, forged, horsepower, pistons, ranger, replacement, t4, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
