Making big HP with the 2.3L. It can be done!
I get 300 ft lbs of tq at 4300 RPMS.
For boost controll I use a 38 mm external waist gate. With an adjustable boost controller from ebay for 20$
With easy driving I get mid 20's.
Tunning was pretty easy I got the pro racer pac from SCT. I had a local shop run it on the dyno to get it tuned in.
It could have ben done a lot cheaper. All you need is the xcal 2 from sct tell them what you are running for injectors and MAF let them know how much boost you are going to run they can send it with a tune for your truck.
Originally Posted by todder53
For you 90mm MAF does it matter what vechile it comes from or can u use any one?
Just as long as it comes from a 95 or later ford car truck or SUV.
You can learn a lot more about turbo rtangers at RPS I am jesshwarren over there. Go to the turo tec in the 2.3L to the 2.5L section.
Sry messed up on the spelling in the above post.
I will have the ranger out of the shop tomarrow.
I installed some new pistons had the block cleaned at a local machine shop. Installed the ARP head studs I am going with a 3 layer steel headgasket 30 psi of boost is going to be a lot of fun! I need this thing to perform as soon as the track opens. I should run low 12's.
Pic below.
Pic below.
#28
#29
Originally Posted by 99F150
is that the origanal 2.5 block or a older 2.3? I didn't think the newer ones had the hole for the distributer.
Also are you using the sodium filled stainless valves like the ones in my 87 Turbo coupe? Or the stock twin plug head.
Stock dual port head.
