Making big HP with the 2.3L. It can be done!
Old 01-13-2006, 10:58 AM
todder53's Avatar
todder53
todder53 is offline
How was tuning your ranger? What did u all do and get from SCT? Also what did u use from boost controll?
Old 01-13-2006, 09:55 PM
Caleb1's Avatar
Caleb1
Caleb1 is offline
what rpm's are ya makin the torque at? If your foot stays light can ya still get 20 mpg?
I would love a setup like that but it would be inna 4x4 truck, so I would need torque to come on fairly low.
Old 01-14-2006, 08:16 PM
95-F250's Avatar
95-F250
95-F250 is offline
Very cool powerdog! There is a Mustang with a 2.5 in the December issue of Car Craft,turbo,nitrous, C-4 trans, 9.80's at 135mph!
Old 01-16-2006, 09:24 AM
powerdog's Avatar
powerdog
powerdog is offline
I get 300 ft lbs of tq at 4300 RPMS.
For boost controll I use a 38 mm external waist gate. With an adjustable boost controller from ebay for 20$
With easy driving I get mid 20's.
Tunning was pretty easy I got the pro racer pac from SCT. I had a local shop run it on the dyno to get it tuned in.
It could have ben done a lot cheaper. All you need is the xcal 2 from sct tell them what you are running for injectors and MAF let them know how much boost you are going to run they can send it with a tune for your truck.
Old 01-16-2006, 06:59 PM
ktravelet's Avatar
ktravelet
ktravelet is offline
thats seriously rediculous, i didnt think this could be done for so cheap
Old 01-17-2006, 10:00 AM
todder53's Avatar
todder53
todder53 is offline
Did u use a blow off valve at all???
Old 01-17-2006, 10:13 AM
powerdog's Avatar
powerdog
powerdog is offline
No i did not.
If I go with blow off it may mess up the MAF meter. I will be installing a bypass valve.
Old 01-18-2006, 09:51 AM
99F150's Avatar
99F150
99F150 is offline
Just curious, why did you go back to the 2.3 stroke? Wouldn't the 2.5 given even more power?
Dan
Old 01-18-2006, 11:27 AM
powerdog's Avatar
powerdog
powerdog is offline
Dan
$$$$ I could do the 2.3 a lot cheaper. Yes I could have made 50+ more hp with the 2.5L but I would have gotten 800+ more $$ in the motor.
Old 01-19-2006, 09:49 AM
todder53's Avatar
todder53
todder53 is offline
For you 90mm MAF does it matter what vechile it comes from or can u use any one?
Old 01-20-2006, 11:15 AM
powerdog's Avatar
powerdog
powerdog is offline
Just as long as it comes from a 95 or later ford car truck or SUV.
You can learn a lot more about turbo rtangers at RPS I am jesshwarren over there. Go to the turo tec in the 2.3L to the 2.5L section.
Old 01-20-2006, 08:57 PM
powerdog's Avatar
powerdog
powerdog is offline
Sry messed up on the spelling in the above post.
I will have the ranger out of the shop tomarrow.
I installed some new pistons had the block cleaned at a local machine shop. Installed the ARP head studs I am going with a 3 layer steel headgasket 30 psi of boost is going to be a lot of fun! I need this thing to perform as soon as the track opens. I should run low 12's.
Pic below.
  #28
Old 01-21-2006, 09:38 AM
99F150's Avatar
99F150
99F150 is offline
is that the origanal 2.5 block or a older 2.3? I didn't think the newer ones had the hole for the distributer.
Also are you using the sodium filled stainless valves like the ones in my 87 Turbo coupe? Or the stock twin plug head.
  #29
Old 01-21-2006, 02:03 PM
powerdog's Avatar
powerdog
powerdog is offline
It is the 98 block that looks like a dis hole but it's not, it's the breather hole.
Stock dual port head.
  #30
Old 01-22-2006, 04:36 PM
handyman43358's Avatar
handyman43358
handyman43358 is offline
Yea, the dizzy hole would be a little further to the left of the breather hole in the pic...
Quick Reply: Making big HP with the 2.3L. It can be done!
