do 16.5 rims come in 5 on 5.5 bolt patterns? - Ford Truck Enthusiasts Forums
Old 12-05-2005, 03:46 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader SwOkcOffRoader is offline
SwOkcOffRoader has a good reputation on FTE.SwOkcOffRoader has a good reputation on FTE.
Ive been told that they do, but i figured id ask on here before my friend and I start searching for something that doesnt exist...so, do 16.5 rims with a 5 on 5.5 bolt pattern even exist in the real world??
Old 12-05-2005, 03:50 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
not sure. but 16.5 tires are hard to find and pricey. i would look for 16'' ones try www.summitracing.com
Old 12-05-2005, 03:59 PM
well the thing is we found a commercial tire dealer that has some offroad tires for 50 bucks apiece that are in decent shape...some are the typical 36" humvee tires and the others im not sure of the brand but they had a decent tread pattern and for the price we cant pass them up, thing is they are all 16.5's....i personally have 16.5 8 lugs on my rig, but my friend has a project with the 5 on 5.5 pattern with 15 inch wheels...we figured if we could find some stock wheels that are 16.5- 5 on 5.5 we could have his project rolling sooner than if we waited for him to save up for the interco's he really wants....most likely he will just stick with the 15 inch wheels he has, but it would be cool to get him rolling on the 37-10.50x16.5 tires we found for 50 bucks apiece....im probably gonna replace my worn out 35" BFG MTs with a set of those 37"s until i can get a new set of MTs...
Old 12-05-2005, 05:12 PM
aurgathor aurgathor is offline
aurgathor is gaining momentum as a positive member of FTE.
Summitracing has some aftermarket wheels, starting around $50. You probably won't find any stock wheels with those parameters, however.
Old 12-05-2005, 08:40 PM
brokebronco's Avatar
brokebronco brokebronco is offline
brokebronco is gaining momentum as a positive member of FTE.brokebronco is gaining momentum as a positive member of FTE.
16.5s are still cheeper than 16s. Look around some more. And you can find tat setup for rims if you look around some. It is not too popular so it will be pricey.
Chris
Old 12-05-2005, 09:19 PM
Cool deal, found the ones on the summit site, thanx for the tip....since they sell them we might find some on ebay or even for sale around town...thanx again guys....
Old 12-06-2005, 12:14 AM
hotrod48 hotrod48 is offline
hotrod48 is starting off with a positive reputation.
What tire dealer is this? I know, or have been told, that the tire shop in Slaughterville sells them cheap.
hotrod48
Old 12-11-2005, 01:24 PM
weldman's Avatar
weldman weldman is offline
weldman is starting off with a positive reputation.
If your going with a standard size tire (anything other than a 39.5 or something) you are well advised to go with a 16 or a 17 inch wheel. 16.5's are dieing!
Matt
Old 12-11-2005, 04:23 PM
Quote:
Originally Posted by weldman
16.5's are dieing!
true, we only considered using 16.5s on his project cause we found 37"-12.50x16.5 tires for 50 bucks apiece....if he is going to spend more money on new tires he is gonna stick with the 15" rims he has cause they are in great shape, plus Interco LTBs are only $109 for 31-10.50x15....it just would be cool AND cheap to go with the 37's on 16.5s......i already have 16.5s on my F-250 and will probably stick with them and buy a set of the 37s until i can afford something better.....
Quote:
its right across the river from pull a part on the corner of se15th and central.....its actually a commercial truck tire place, but they have a selection of smaller tires, 36's being the smallest....they have a brand new set of BFG MTs i was drooling over, but i never did get a price on them...
Old 12-11-2005, 11:44 PM
I was looking at a truck this past spring that had the Humvee tires and he said he got them in Slaughtrerville. I wish I had enough lift and gear on my 81 to run them. Are you going to run some on your 78? Does this guy have any dirt cheap 31-33" in a somewhat aggreseive tread?
hotrod48
Old 02-10-2006, 04:15 PM
Dino@his Dad's Dino@his Dad's is offline
Dino@his Dad's is gaining momentum as a positive member of FTE.
16.5s with a 5 x 5.5 pattern
SwOk, I don't know of anyone who stocks wheels in that size, but Stockton Wheel can make them that way for you. 65$, IIRC. DF
Old 02-15-2006, 10:02 PM
vman vman is offline
vman is starting off with a positive reputation.
It was many moons ago,but I had a 68 intertrational with 5.5 bolt pattern 16.5s about 10 inches wide.They were just a plain steel wheel.
Old 04-06-2006, 02:14 AM
74 F100 351m's Avatar
74 F100 351m 74 F100 351m is offline
74 F100 351m is starting off with a positive reputation.
SwOk do they have any 14x20 the 46" military tires?
Old 04-06-2006, 11:32 AM
im not sure about military tires, but they are a commercial tire dealer so i bet they have somekind of offroad 20" tire, i seen alot of AG tires and tractor like tires out there...they have alot of tires id love to put on a 4x4 if i could find 20" or larger wheels...
Old 04-07-2006, 11:53 AM
I'm having fun trying to find 20x10"s that don"t go over $200.00 a wheel.
to do or not to do jamusfam Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 06-23-2015 11:35 PM
16" Stock Rims, 5 x 5.5" pattern IdahoDoug Ford Truck Parts for Sale 0 04-23-2015 02:27 PM
8 Lug 16.5 in rims Redneck1465 WTB - Parts & other 17 03-01-2013 06:14 AM
8 lug 15 inch rim? buttnuttn8 Offroad & 4x4 8 03-02-2005 09:30 AM
16" or 16.5" 5 lug rims impact 1987 - 1996 F150 & Larger F-Series Trucks 9 09-18-2002 05:24 PM
Tags
165, 165rims, 55, 555, 5on, 5on55, 825, bolt, ford, inch, rim, rims, steel, wheel, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
