1.0 or stock turbo
i would go with the 1.0 loss of a couple pounds of boost isnt as bad as alot of people think it is. your getting a cooler denser air charge into the motor making it more effecient. a 1.0 will spool up alot quicker. but it will move your peak rpm range down a little. moved mine down to about 2400rpm it was about 2800rpm with the 1.15
the efficent range moves down. you can see this in the flow charts for the turbo with that housing. you can still make more boost up higher but your drive pressures start getting higher and egts will be higher also. the smaller housing cant move the volume of air in the higher end. another thing that works well is a larger compressor wheel in conjunction with the slightly smaller housing.
i took mine to a local turbo shop in town and milled/polished the inside of the compressor housing out and put the larger compressor wheel in it. theres a 88mm compressor wheel in there now. eventually im going to twin the truck or just go with a gt38r it would be basically the same turbo i have now but ball bearing.
