no fuel need help
no fuel need help
well the weather today is about 10 degrees. i went out to start my 95 and got it going, running real rough) figured its cold. about five minutes later it still running on only a few cyclinders. now i am late for my daughters performance and have to take my 70 merc cyclone out in the snow. (big block and 4 gear and Detroit locker) that was fun, not. any how i stopped and picked up a new fuel filter and glow plugs. install the f.f. and hit it wont start. pull the top of the fuel filter of and i am not getting any fuel to the filter. no blown fuses i see and not sure where the fuel pump relay is. The trucks in the heated garage now figured maybe there is water in the fuel line, but I am still not getting anything. what gives?????now the cyclone has 6 inches of snow on it and I have a dead truck.
As barebackjake said fill the fuel canister with Powerservice DieselKleen or Stanadyne. Because it's a mechcanical fuel pump, if you drained the canister when you replaced the fuel filter and do not mannually fill the canister with diesel fuel or DieselKleen, it can take a lot of cranking to re-fill the canister.
i did fill the canister with fuel afterwards.after sitting the warm garage and being plugged in i was able to fire it up. then i did make sure i am getting fuel, wich i was. now i think my batteries are junk and its not a fuel problem. the truck starts and runs well for about 30 sec then starts running real bad. i have charged the batteries and check them i only have 12.3 volts per battery.the batteries were bought from that useless walmart exactly 13 months ago. this aft i will take themout and have checkedat a local parts store. my ampmeter goes up and down with engine speed once it is running correct me if i am wrong but that would tell me its working good( the altenator)i will keep every one posted. do you have any ideas why low batteries would keep it from running well once it has been started?jack k
Being mechanical fuel pump it will run just fine. But if you run very low on battery or charging. The fuel shutoff will slam shut and you will have no fuel. If you need batteries get a 1000cca with a 60 month warranty. if they fit into the battery area.
this time of year get a good grade of fuel from a major supplier. I have used premium and 5% bio and have never had a problem.
there is no electric fuel cutoff on theese trucks when the battery power gets low its not able to fire the injectors and control the injection pressure thats the problem with weak batteries. when the truck is cold and the glow plugs and fuel heater are on the voltmeter will fluctuate when you bring the rpms up and down due to the alternator producing more power. it dosnt produce its full potential untill 1800rpms. the lower the rpms the less power its producing giving more of the load to the batteries. there have been quite a few people that have had issues with the walmart batteries so i would go down that route.
you can check fuel pressure on the shrader valve on the side of the bowl with a regular tire pressure gague that goes to 100psi.
go drive it for a while and go easy on it. see if it gets better. or plug in your block heater for an hour or so. then start it and see how it is......
i have owned this truck for 5 years and itsnever run like it is now.there is something wrong.i have new gp to put in but need toget the problem fixed first. the garage is 60 degrees. and its been that way since 8pm last night.didnt change anything. thanks for the reply. when muma gets homei will have the batteries checked untill then i am justa babysitter. jack
