NP203 oil and capacity? - Ford Truck Enthusiasts Forums
Old 12-03-2005, 04:08 PM
MBBFord's Avatar
MBBFord MBBFord is offline
MBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to behold
Question NP203 oil and capacity?
Ok, I can't remember what oil goes in the 203 and what is the oil capacity.
I want to say 30W motor oil, but not sure if 10W30 or 10W40 would be preferred.
Also 7 quarts sounds right, but don't remember.
Thanks for any comments.
Old 12-03-2005, 10:49 PM
7FORD2 7FORD2 is offline
7FORD2 is starting off with a positive reputation.
ok its 10w40 and its 9 not 7 quarts
Dustin
Old 12-04-2005, 08:00 AM
MBBFord's Avatar
Thanks for the help, I couldn't remember.
Old 12-04-2005, 08:06 AM
The SnoMan The SnoMan is offline
The SnoMan is new and has a neutral reputation at this point.
Quote:
Dustin
It is supposed to be straight 30w non detergent oil. You can use straight 20w in winter. You do not want to use a multi vis detergent oil which will not lube it as well and tends to foam up in case too! (non detergent oil will not foam)
Old 12-04-2005, 08:44 AM
MBBFord's Avatar
I've seen both use, I've actually seen people use 90W and sware that's what is suposed to be used, but it is 9 quarts of 30W right?
Old 12-04-2005, 01:09 PM
Quote:
Yes or until it runs out of fill plug. I cannot varify capacity in manuals here but I can varify the 30w. I am thinking closer to 7 quarts though. I was driving when they first came out and remember that Tcase well!!
Old 12-04-2005, 06:56 PM
MBBFord's Avatar
I'll try doing some more research, but thanks for the info so far guys.
Old 12-05-2005, 05:12 PM
1975Ford's Avatar
1975Ford 1975Ford is offline
1975Ford is gaining momentum as a positive member of FTE.1975Ford is gaining momentum as a positive member of FTE.
I've seen on a shop manual and it's calling out 50w on t-case.
Old 12-05-2005, 08:32 PM
ok guys this what my 79 ford truck manual says its 9 quarts of 10w40
Old 12-05-2005, 09:11 PM
Quote:
The manuals are in error. I remember when those things were new. New Process (who made the case for Ford, GM, Dodge and IH) spec'd it for striaght 30W non detergent oil in summer and you can use striaght 20 in winter if it gets below zero a lot. DO NOT USE MUILT VIS OIL regardless of what manuals may say as it lasts the longest with regular changes of non detergent oil which does not foam like muiltvis oil can do with the high chain speeds at times in that Tcase. All of those engine additives in modern muilty vis oil are of no value to keeping your Tcase alive.
Old 03-28-2015, 09:29 AM
Johnny Be Cool Johnny Be Cool is offline
Johnny Be Cool is starting off with a positive reputation.
Ok, last post was in 2005, times have changed and there are so many different opinions on type of fluids.
Now what is the fluid viscosity used today and how many quarts?
Oil 10w30 GeneLaw1 6.0L Power Stroke Diesel 21 04-06-2012 04:02 PM
Oil Change capacities 1997 F250 LD 5.4 Liter 97F250LD4X 1997 - 2003 F150 4 12-23-2010 11:48 PM
F-800 429 Oil Choice? Dstosh Large Truck 4 11-14-2009 11:59 AM
30W motor oil in transfer case? sigtauenus Clutch, Transmission, Differential, Axle & Transfer Case 3 04-26-2007 07:45 AM
Fluid Capacities Help Lone Wanderer 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 10-29-2005 08:47 PM
Tags
c4, capacity, case, check, dodge, fluid, ford, level, manuals, np203, np205, oil, recommended, specs, transfer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
