00' 5.4L - "spuddering" type symptom in overdrive??
Old 08-26-2014, 01:32 AM
FordTruckChuck's Avatar
FordTruckChuck
FordTruckChuck is offline
The Accel's say they have a Turn Ratio 61:1. What does that mean?
  #47
Old 08-26-2014, 03:35 AM
FordTruckChuck
Originally Posted by Bluegrass 7
Either find OEM replacements or go to ROCK AUTO and select one of their well known brand names.
I would use a Scanner to look at the misfire monitors and see which ones need replacement if you don't want to go with a full set of OEMs.
The problem is the public likes the low cost but has no way of knowing history of them.
At least with OEM, FORD has used them from back in the early 90s on the first COP equipped motors on the production line to this day.
Like any part they do have limits on their life span but not like the unknowns or cheap imports or you would not have an issue.
I think from about 80k up +/-, the OEM coils can fail due to the very harsh climate they live in on any motor. After all they are a maintenance item same as tires, plugs, brakes or shocks.
They get heat cycled from the head temperature, heat from the radiator, heat from the exhaust manifolds and a closed engine compartment after the motor is shut down as the temp usually rises for a few minutes then begins to cool.
This breaks internal wire connections from expansion/contraction wire fatigue (sets a code) and can cause shorted turns that is the source of misfire in OD that 'does not' set a code..
Only here will you get this perspective and experience.
Good luck.
Well Rock Auto has Motorcraft coils for $41.79ea. I guess that would be the way to go.
Interesting that you mention about engine compartment heat cause when I get home after driving around when the weather is warm I open the hood to let all that heat out & leave it that way till it cools off.
  #48
Old 08-26-2014, 10:28 AM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
You lost the basic cause of the misfire by hoping a plug change will clear the misfire.
It will not if there is a coil that has low output.
A plug might seem to clear the miss under 'marginal' coil conditions but it will come back to haunt you in less than 1000 miles later after the plug tip begins to erode so you end up doing double work.
You have to get over this either not looking for the coil that is faulty by using a scanner or replace all the coils hoping one of the replacements is not faulty out of the box (it does happen now and then).
This is the reality of the situation you have to deal with.
You got all the info that normally is not available like this.
Do it right or enjoy the ongoing hassle.
Good luck.
  #49
Old 08-26-2014, 01:29 PM
FordTruckChuck
Can anyone confirm for me if the Motorcraft coil part # is DG508?
Disregard this...I was able to confirm it by checking the # of the one I had bought awhile ago.
Apparently I don't possess the magical powers that would enable me to delete my own posts.
  #50
Old 08-26-2014, 06:09 PM
whateg01's Avatar
whateg01
whateg01 is offline
...You have to get over this either not looking for the coil that is faulty by using a scanner or replace all the coils hoping one of the replacements is not faulty out of the box (it does happen now and then).
Good luck.
I don't remember all of the details from the OP, but on my engine, I didn't have any codes and the mode 6 screens all showed no counts until I replaced the plugs. Then, after that, the P0302 code was set. I wonder if with so many random misfires, the computer couldn't calculate what the "right" rotation per cylinder was.
  #51
Old 08-26-2014, 06:11 PM
whateg01's Avatar
whateg01
whateg01 is offline
Originally Posted by FordTruckChuck
Thanks for the info, whateg01. I wonder if it would be even easier if the hood was removed.
I don't think it would really matter. It's the cowl that really gets in the way. In my case, the hood was shading me from the sun beating down on that 100 degree, 98% humidity day with no breeze!
  #52
Old 08-27-2014, 01:39 AM
FordTruckChuck
That sounds very unpleasant. I guess waiting for a cooler day was not an option.
  #53
Old 08-27-2014, 01:46 AM
FordTruckChuck
Well I just ordered a set of 8 Motorcraft coils thru Amazon for $309.88 ($38.74ea)
& Motorcraft plugs thru ebay $2.99ea.
We'll see how it goes from here.
  #54
Old 08-27-2014, 03:58 PM
whateg01's Avatar
whateg01
whateg01 is offline
Oh, and I had to walk uphill both ways to get to the truck. It was on the weekend, and I was to be out of town most of this week. In fact, I just got back home now. Needed to get the truck running, though, so I can get the one it's replacing listed for sale. Can't be without one with the jobs I have waiting to go to powder coat. Can't fit those in the car. So, yeah, it had to get done. I lived. Good luck with your truck. Hopefully, the coils take care of it all!
  #55
Old 08-27-2014, 05:25 PM
Dr. Dirt's Avatar
Dr. Dirt
Dr. Dirt is offline
since yours is a 98 does it have separate coils for every cylinder. or is it just the 4.6 that has that?
  #56
Old 08-27-2014, 05:26 PM
FordTruckChuck
Thanks, whateg01.
  #57
Old 08-27-2014, 05:54 PM
FordTruckChuck
My 5.4L has COP's.
  #58
Old 09-08-2023, 09:29 PM
Bluegrass 7
Even if this is an old thread there are things to offer.
1. If a coil is faulty and fails to output enough voyage under light throttle >>when the EGR valve is commanded to open, it is because the Air to Fuel Ratio becomes very Lean. this is norma but requires the coil voltage be above amin level to fire that charge.
If it does not, misfire is the result.
2. This can be verified by looking at the mode 6, test 53 record of misfire in the program.
This misfire record cannot set a code but keeps the history because the misfires come and go according to the driving condition.
3. The Oil stabilizer is a viscosity improver that would help improve Ring Seal more than affect the cause of misfire.
Just something for you in case the issue returns.
I use a 1 qt. of viscosity improver to 5w20 oil in my 25 year >newer engine< a 5L DOHC for an improved Ring Seal due to a factory quality control production issue along with another Additive to solve an Oil usage issue right from the assembly line.
Good luck.
MODERATOR NOTE: The post about oil additives has been removed.
Last edited by 85e150; 10-17-2023 at 08:30 PM. Reason: add note about removed post.
  #59
Old 09-09-2023, 02:13 PM
FordTruckChuck
Question
Good luck.
What are the additives you use and would you recommend them for my 98 5.4L with 100k on it?
2006FOMOCO
10-15-2023 06:12 PM
bfree65
2004 - 2008 F150
07-10-2011 10:05 PM
Garff
1997-2006 Expedition & Navigator
11-20-2010 05:36 PM
knkdel
1997 - 2003 F150
09-22-2003 12:32 PM
gwinters
1997 - 2003 F150
07-22-2002 01:28 PM
Quick Reply: 00' 5.4L - "spuddering" type symptom in overdrive??
