Headlight switch removal blues...
Hey Guys,
If someone could tell me how to remove the panel beside the steering column that has the light/wiper ***** through it I would appreciate it. The truck is a 1990. I've searched and found a bunch of post reffering to the tach article, but that year has a different dash than my truck.
Basically, the story goes like this:
Bought the truck and was told the front take "didn't work". I siphoned the gas out, because it was very old (didn't want to plug up my injectors). I tried turning the key with the Tank Switch to "F" and the fuel pumps do not come on. I checked the conneciton on the sending unit and it appears to be good, so I'm assuming it is the switch on the dash that is the problem.
To get at the switch, i have to remove the dash panel. To remove the dash panel I have to remove the headlight/wiper *****.
On my old 81 Ford there was a spring loaded release button oin the side of the switch i could reach up under the dash to hit. I can reach anywhere near the switch on this truck.
I tried poking around int he notch on the ***** but couldn't release the ****.
Starting to get a bit frustrated having this much trouble with a simple thing.
Thanks in advance,
Mike
Thanks in advance,
Mike
Hey Mike,
I have a 92 F150 to remove mine I pull the light switch on and use a small pick there is a spring inside the **** and you push toward you and it should release if not put a pair of plilers on shaft and pull kinda hard on the ****.
Too Funny on this switch
Once I read the instructions in this post, I carefully inserted a very small screwdriver into the slot and pulled. After fighting me with such force before, the **** shot into the seat back, bounced into the street and rolled under the truck. Lol.... But the parking lights work again thanks to y'alls help!
Thanks to all.
Thanks to all.
334eagle
05-21-2010 08:35 AM
cybercrone
03-16-2007 06:36 PM
Roushians
15
03-20-2005 09:34 AM
sigtauenus
03-15-2002 10:45 AM
Herdsman
02-27-2002 03:55 PM
